Question about Nokia E71 Smartphone
How do I set Nokia E71 keypad to unlock with PIN in screensaver
How do I set my Nokia E71 keypad to unlock with PIN when in a screen saver mode? Currently it only asks for PIN upon switching on, but not when in screen saver mode (in the latter it asks to press "unlock" and then "function key".
This problem, my phone get the dialog pin when i install settting GPRS&MMs
Posted on Aug 03, 2011
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
I need my unlock code !
Here's the fastest way to unlock your phone... just visit this site http://www.imeiunlockcode.com you can purchase an IMEI unlock code for your Blackberry, HTC, LG, Motorola, Samsung or any other GSM phone and unlock it in seconds. its 100% safe (no loss of data or contacts). All you need is type the IMEI unlock code and your phone is 100% SIM lock free.
Jan 25, 2011 | Nokia E71 Smartphone
My nokia E71 cannot be unlocked. the keypad wont function. After several periods of turning on anf off, the displays is " continue using phone in offline mode? hoe can i select the answer between yes or...
had the same problem... remove the battery for an extended period of time and try again. unfortunately for me the phones screen now refuses to turn on, the keyboard woks now but the screen is completely black- best of luck with yours
Aug 22, 2010 | Nokia E71 Smartphone
How can the standby mode on the Nokia 2730 be fixed.
first decide that in your phone activated your screen saver if yes then customize your display setting. if not then active your screen saver which is watch.if you not get any solution then format your phone. these code are under the following.
*#7780# then want security code. please give your security code. then your phone will be restore factory settings.
Jul 03, 2010 | Nokia 2730 Cell Phone
Putting a lock code on an e71 to unlock phone
It is possible to put code on E71, You go to settings then security, you will enable the keypad security code and enable your phone code also. With these nobody can access your phone without asking for security code. Take note Phone, sim and keypad pin code must be enable. Thanks
May 13, 2010 | Nokia E71 Smartphone
Screensaver 4 n72
go to galleries ,select graphics & then screen saver .from here u will get screen saver provided by & if u want ur file as screen saver ,go to that picture open it , open options->use image->set as screen saver
Aug 05, 2009 | Nokia N72 Cellular Phone
Screensaver not working
just go in setting there will b optin of screen saver click it then you should click on the screen saver it will b on..
May 23, 2009 | Nokia N95 Cellular Phone
Remove icons from screen
goto menu,tools,settings,general,personalization,standby mode
there set active stand by to off.then you can see the screensaver
Sep 01, 2008 | Nokia N95 Cellular Phone
Nokia n72 screensaver activation.
You need activate it under
Themes->Power saver->(Select a theme)
You can preview it under
Themes->Power saver->(theme)->Options->Preview
Aug 20, 2008 | Nokia N72 Cellular Phone
Nokia E71 Smartphone Logo
363 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
