Question about Samsung HCL4715W 47" Rear Projection Television
Convergence board for Samsung HCL4715w
I got a new board and installed it. It didn't fix the problem. i can unplug the board turn on the tv and it looks the same as it does plugged in?
Wally
  • Samsung Master
  • 8,617 Answers
The Convergence ICs will need to be replaced , 95% of the time thats the problem they are on the sub board not the convergence board. You will need two STK392-040 ICs . you can get replacements at the following link and they will provide free installation instructions along with free on-line tech support when you install them. takes about 45 minutes. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 21, 2008
  • Sonny Berry
    Sonny Berry Apr 25, 2008
    The stk 392-040 ICs are whats giving you problems they are on the sub board not the convergence panel
Samsung HCL4715w Hdtv convergence issue
Maybe you can fix it in the service menu.
Turn off TV, press mute then 182, Turn on TV and check out new menu items
Jan 24, 2013 | Samsung HCL4715W 47" Rear Projection...
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Anyone need any parts for the HCL4715W? Parting mine out.
More then likely set has 2 burt resistors on convergence board 2.7ohms
Jan 27, 2009 | Samsung HCL4715W 47" Rear Projection...
Convergence Board for hcl4715w Samsung TV
Part can be found at http://www.vancebaldwin.com - the part is located on the floor of the tv, inside, the middle board. You will have to unplug the tv, carefully remove the back (and front speaker cover) of the tv, and unplug all of wires coming into it. You will also have to remove all of the screws holding it down. The replacement part will fit exactly into the same place - screw the screws back in, plug the wires back into the same place (if you've ever replaced memory in a computer, this will feel very familiar). Once everything is plugged back up, plug in the tv and restart, then run the smart convergence from the remote.
If your TV does not power up, and you have made VERY sure everything is plugged in correctly, then the board you've purchased may be faulty. Return it for a new one. The boards are fragile and can be bad straight out of the box (like computer memory *smile*).
Best wishes -
Jan 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Help me fix my 60 inch projection samsung
try unplugging the three convergence yoke plugs then try powering up the set if it powers up the Convergence ICs are bad and will need replacement.
Jul 25, 2008 | Samsung HCL4715W 47" Rear Projection...
Replacing Convergence ICs
As long as you can solder you should be okay, however i would suggest getting your ICs at the following link because they provide free instalation instructions with pictures on how to remove and replace the Convergence ICs. heres the link.
Apr 26, 2008 | Samsung HCL4715W 47" Rear Projection...
How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Apr 22, 2008 | Samsung HCL4715W 47" Rear Projection...
TV won't power on
Disconnect the convergence board and see if the set comes on. If it does, and it probably will, replace the convergence board or the convergence amp IC's. Good Luck
Jul 26, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
480 people viewed this question
Henry  Thomas
Henry Thomas
