Question about Air Tools & Compressors
I have a clarke air compressor model no SE14A150 4HP.ineed to get some parts.it has no pressure switch,it keeps running until i unplug it,i have no manual either?
SOURCE: air compressor 3 gallon
When I turn compressor on it does not build up any pressure ?
Posted on Oct 25, 2008
  • 1388 Answers
SOURCE: Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Posted on Jan 03, 2009
  • 19 Answers
SOURCE: Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Posted on Feb 02, 2009
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 98 Answers
SOURCE: where would I find a manual for a clark air
Needs new valves
Posted on Jul 21, 2009
Clark air compressor parts
Most compressor shops will stock the part
Aug 17, 2014 | Air Tools & Compressors
?? LOCATE A MANUAL/PARTS DIAGRAM FOR CLARKE AIR COOMPRESSOR
You didn't state your model number but the only place I could find that has manuals for Clark air compressors is Clark Power Porducts UK at: www.clarkeservice.co.uk/product_manuals/air_compressors.shtml. Usually if you have an air leak at the pressure switch when the tank is full and after the motor shuts off it is indicative of a stuck or broken tank check valve. Sometimes they can be cleaned and will work for a while but more often than not they have to be replaced.
Sep 06, 2012 | Clarke Air Tools & Compressors
Looking for parts for a Clarke air compressor
try machine mart in uk they are main agents for clarke machines over here
Jul 06, 2012 | Clarke Air Tools & Compressors
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
STARTS AND RUNS FOR 30 SECONDS THEN SHUTS OFF, STARTS AND RUNS FOR A COUPLE SECONDS KEEPS DOING THIS. I SUSPECT IT HAS A THERMAL SWITCH. WHERE IS IT? CAN I WIRE AROUND IT?
Hi
Yes I think you may be right, it could quite well the thermal switch,"pressure controlled on/off"switch and is not properly set up, minimum and maximum stop/start.
If what I see in the photo, the pressure switch is beside the top tank with a pressure gauge on it, and the electrical supply should feed into/from it.
Hope this gives you a little food for thought, and hope that it is a little helpful
Cheers
John
Jul 19, 2011 | Clarke Power Products AC2002A 2 Hp Air...
Adjust cut out switch on Clarke AC2525 Air Compressor
hi mate on the pressure switch in the middle there will be a screw unscrew it and pull the cover off and inside you will see a screw or a bolt it is straight on top you cant miss it it will have a +/- on the left or right of it unscrew to decrease pressure screw in to increase pressure but unplug the machine before you do
Aug 27, 2009 | Clarke Power Products AC2002A 2 Hp Air...
I broke the red on off switch, on my preasure switch
IF YOUR TALKING ABOUT THE ON/OFF SWITCH ON YOUR PRESSURE SWITCH JUST REPLACE THE PRESSURE SWITCH WITH A NEW ONE FROM ANYWHERE - ONE THAT HAS THE SWITCH ON THE SIDE. TAKE YOUR OLD PRESSURE SWITCH WITH YOU TO MATCH IT. IF IT HAS SOME FANCY SWITCH MADE INTO THE COVER YOU CAN ADD THE PRESSURE SWITCH WITH THE SWITCH ON THE SIDE OR JUST BYPASS IT ALL TOGETHER. IT DOESNT EVEN HAVE TO BE THERE, THE COMPRESSOR WILL SHUT OFF AT CUTOFF PSI ANYWAY AND YOU COULD UNPLUG IT TO KEEP IT FROM RUNNING WHEN YOUR NOT USING IT. THE PRESSURE SWITCH W/ ON/OFF ON THE SIDE IS VERY AVAILABLE. HOPE THIS HELPS, JODY
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Dec 09, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
102 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
