Toshiba 27 I have a Toshiba CX2789K that has one horizontal line across the screen that is about 3 inches wide. There are a few smaller horizontal line lines on on the top half but the bottom half is blank. Can you help? Thanks
  • MeTV Apr 21, 2008
    The Sound works fine.
    I will start looking into the vertical deflection amplifier section.
    Not sure what you mean by "Check the resistor"?
  • Bronz May 23, 2008
    I have a horizontal line in the middle of the tube and I wanted to know if the problem is with the projection lamp?
You just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Posted on Apr 19, 2008
Horizontal white lines across top of screen. About two inches from the top, some channels more pronounced than others but always there.
Check for dry electrolitic capacitors near the vertical Ic output maybe one of 50v to 100mf or 50v to 10mf
Jul 24, 2010 | Toshiba 27A43 27" TV
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Thin black horizontal line across the middle of the screen
It looks like you've got problems with your screen. If that one is on a warranty, replace it
Jan 22, 2018 | Westinghouse W32701 27 in. LCD HDTV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
Televison & Video Logo
514 people viewed this question
Top Televison & Video Experts
