Question about Coleman Pressure Washer PW0881800
What type of oil does the coleman pressure washer model#pw0912500 take
2 Suggested Answers
sflummox
  • 91 Answers
SOURCE: I have a Coleman 2200 6hp green tochemsa engine
The recommended oil is determined by the pump manufacturer (usually different from the engine), but most of the "consumer grade" pressure washers say you never need to change the pump oil. Maybe they figure something else will break before it needs new pump oil?
The little jugs of pump oil at home improvement stores are usually SAE 30W (non-detergent) crankcase oil. 75W90 gear oil seems like a better choice; I personally use synthetic marine lower unit gear lube in my pressure washer pump. It's a little more expensive, but I think the formulation gives better moisture resistance. Besides, the pump takes a fairly small amount, and I don't change it very often at all.
Bottom line- you almost certainly want non-detergent oil, around 30W crankcase/80W gear (since they use different scales, these are just about the same viscosity). Synthetics seem to be higher quality, and using marine grade lube gives me peace of mind.
The pump oil matrix here is illustrative- note the many substitutions allowed. The specific oil you choose probably doesn't make much difference, especially compared to never changing it.
Posted on Jul 16, 2011
Testimonial: "Thank you, youre right about the marine grade oil I have some and I will try that, danmanthepickleman."
I have a Coleman 2200 6hp green tochemsa engine pressure washer and wanted to know what type of oil is used in the water pump? PLEASE LET ME KNOW.
Jul 16, 2011 | Coleman Garden
Coleman Powermate pressure washer PW0872400.01
The systems are simple but if they aunt stored correctly(allowed to freeze) or the air isn't purged out of it. It can result in damage to the machine.If water is dripping out of the pump it is damaged. if not then it could be air (purge system), or a damaged or stuck check valve.
Apr 26, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman 1600 pressure washer
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Apr 13, 2009 | Coleman Pressure Washer PW0881800
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman Pressure Washer PW0881800 Logo
374 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
