Question about Lexmark P707 Photo Jetprinter InkJet
How do I install an ink cartridge in a lexmark P707 printer
  • Official Brand Answer
  • 3,344 Answers
Perhaps the Lexmark P707 User's Guide will be able to help you. Just click on this link: http://bit.ly/9Rw4RC. Scroll to Replacing the print cartridges, Page 43, for instructions on how to install/replace the cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Posted on Jul 12, 2010
2 Suggested Answers
SOURCE: Lexmark printer, model P707- just
clean and realign cartridges and printheads, with printer software
Posted on Mar 29, 2011
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    How to replace the ink cartridge
    1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
    2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
    3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    do rate the solution if it helps
    Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
    Lost my manual, need to change the ink cartridge, help
    3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    Apr 24, 2010 | Lexmark C533DN InkJet Printer
    Using a refilled ink cartridge on a Lexmark x4850
    Yes, most Lexmark cartridges as well as many other manufactures use something called 'Smart' Chips in the bottom of the ink cartridge. Usually unplugging your (about 10 seconds) printer resets the memory in the printer. Hope this helps!
    Mar 20, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
    Lexmark P707 prints worse with Photo cartridge
    I lost my drive cd so I need free driver download lexmark p707 printer.
    Sep 24, 2008 | Lexmark P707 Photo Jetprinter InkJet
    Won't print text
    This is a photo printer. My regular printer will not print photos and if I am correct photo printers will not print regular documents. They are made for separate document types (ex. doc and jpeg). This is so the corporate winners can steal more money from the consumer. I am sure there are printers out there that do both, but your printer is specifically a photo printer. Ask a tech at Best Buy or Circuit City. Let me know what they say.
    Cynthia Charczenko
    Jan 15, 2008 | Lexmark P707 Photo Jetprinter InkJet
    Lexmark P707 Photo Jetprinter InkJet Logo
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
