Question about LG GCC4521B CD-RW/DVD-ROM (Combo) Burner
The dvd rom doesnt starts it doesnt even lights the green bulb.
    President:
  • 2,571 Answers
Sounds like the power lead at the rear of the dvd drive has come loose or is faulty.
You will need to open the pc and check that the power lead is fitted correctly, you may need to try another plug, you may have a spare you can swap it with.
Posted on Jul 11, 2010
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
My lg dvd rom is not reading dvds
Try deleting upper and lower filters of your optical drive. To do that, run regedit on start search. Then, follow this path: local machine, system, current control set, control, class, 4D36E965- E325 - 11CE - BFC1- 08002BE10318. then on the window under Name, look for upper and/or lower filters. right click on it and delete. restart pc. then you're good to go.
May 26, 2010 | LG GSA-H55N DVD-RAM Burner
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
My acer aspire 5315 dvd rom doesnt work at all but somtime it do
There is a problem with the DVD ROM. Maybe it is not well fixed and causing conflict which result in making the computer slow. And maybe it is not contacting the system well again, that's why it worked and later not worked when it loose contact.
I would advice that you shut down your system, loose the DVD ROM and put the system back on without the DVD ROM after a little while when the windows must have settled, shut down the system again and fixed back the DVD ROM. Make sure it is well connected and put the system back on again. Test the DVD ROM and see if it would give the same problem. If it does, then may be you will have to replace the DVD ROM.
One a DVD ROM is bad, another one needs to be purchased, because it is usually difficult to repair DVD ROM expect in minor case.
I wish you the best.
Dec 18, 2009 | Acer Aspire 5315 Notebook
Dvd rom
Try to check the IDE connector and power supply of the DVD. also check the jumper setting of your DVD whether its slave or master. good luck!
Jun 17, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Doesnt boot from DVD rom
Hi
I know it sounds a bit odd but were u using a bootable disk to boot?
If yes, then try epgrading ur BIOS version it may help.
Jun 01, 2008 | Dell Inspiron E1405 Notebook
Cd/dvd drive
your cd rom is brike you need to buy a new one
Nov 27, 2007 | Acer Aspire 3610 Notebook
DVD ROM STOPPED WORKING & GREEN LIGHT KEEPS BLINKING EVEN W/O A DVD OR CD
clean the dvd player if that doesnt work it has to be replaced.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Nov 19, 2007 | Microsoft Xbox 360 Console
LG GCC4521B CD-RW/DVD-ROM (Combo) Burner Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
