Brother HL-1435 laser printer does not print uniformly. Some of the text is very light, almost illegible. I have replaced the toner cartridge but it still prints poorly.
I found a FAQ site about the Brother printer.
Posted on Apr 20, 2008
Where is the cartridge on a brother laser printer HL-1400
I don't see a Brother HL-1400 on their site. However, there is an HL-1440 which uses the TN-430 (regular) or TN-460 (high yield) toner cartridges. This printer also takes the DR-400 drum unit.
This toner cartridge works with several models in the HL-1400 series, including the HL-1435, HL-1440, HL-1450 and HL-1470N.
I hope this helps.
Aug 25, 2016 | Brother HL Office Equipment & Supplies
Brother HL-1435 printer not printing. Alarm and data lights stay on. I tried replacing the toner, replacing the drum, factory resetting printer (both are genuine Brother products), uninstalling and...
try reseting drum unit
Open the front cover. Locate the black button under the LED lights on the left side. Press and hold in the button until all the lights are lit. Release the button. The counter is reset!
its toner soup
Nov 18, 2013 | Brother HL 1435 Laser Printer
I needed to print a page off my laptop and put the usb from the HL-1240 Laser Brother printer and it refuses to print, even though it is set as the default printer. Does the printer have to plugged into...
When you plug the printer in to your computer it will either install automatically (using the HL-1435 drivers) or if it is already installed it should come online.
If the printer is not doing this then you need to look on the printer to see if any of the LED lights are on or flashing. The toner cartridge might be empty or you might need to replace the drum unit.
Check the lights and you can see what they each mean on the Brother website using the link below.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1230_all&Cat=11
Thanks,
Pat
Nov 09, 2010 | Brother HL 1240 Printer
I have a couple Brother Printers HL-1435 that are in alarm status and will not print. The Drum light will flash, and then the Drum, Ready, Alarm and Data lights all flash at the same time. How can...
This could mean one two things.
* The toner cartridge is nearly empty.
* You have a paper jam.
To replace toner cartridge:
Click this link to go to the Brother site where it will show proceddure with illustrations how to change the toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_011.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=7
To clear a paper jam:
Go to this link for procedure. It also has illustrations to assist you.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_005.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=113
I hope this helps.
Aug 04, 2010 | Brother HL 1435 Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
May 01, 2008 | Brother HL-2040 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
71 people viewed this question
jasbo
jasbo
