Question about LG Flatron 563LE 15.1" LCD Monitor
How can I have a driver for monitor LG flatron LCD 563LE?
    Brigadier General:
  • 4,044 Answers
You can download the Drivers for your monitor from the LG website.
Posted on Jul 11, 2010
  • ctyler165 Jun 02, 2011
    That stinks! You are a **** for putting an advertisement as a disguised link. It is people like you who give the Internet a bad name!
Driver download
type "driver LG FLATRON L1919S" in Google, you'll get the answer...
Aug 30, 2014 | LG Flatron L1919S LCD Monitor
HOW TO FIX LG FLATRON 1750HQ OUT OF RANGE WITH WINDOWS XP?HOW TO START THE MONITOR ON A WINDOWS XP IT WORKS ON VISTA HOWEVER ON XP WINDOWS IT SAYS OUT OF RANGE WHAT ARE THE CORRECT SETTINGS FOR WINDOWS XP...
your refresh rate is set too high. boot into safe mode set to 640 x 480 then reboot. once it is up try adjusting the refresh rate to around 60 or lower. or buy a newer monitor.
May 20, 2014 | LG Flatron 563LE 15.1" LCD Monitor
White display on my lg flatron L192ws
Most common problems with LCD monitors arises due to weak or damaged capacitors. Disconnect the power and signal supply from monitor, then open the case gently. Use a flat screwdriver for pry opening the case, after removal of screws. Here you have to look for faulty capacitors on the circuit. On the PCB of the monitor, check each capacitor for deformation/leakage around it. In case of any doubt, it's better to replace the capacitor, as they are inexpensive. The only thing is that you should use the correct rating capacitor for replacement. You will need a soldering iron, and at best a multimeter for carrying out the job. After doing all this, assemble the monitor back, and your monitor will be working fine.
Caution : If you are finding yourself uncomfortable with all the work doing yourself, then ask for help from a qualified technical person.
Nov 01, 2010 | LG Flatron 563LE 15.1" LCD Monitor
I need a driver for the LG Flatron L1919S LCD Monitor
for what purpose you want the driver for the monitor? generally there are no need to install the monitor driver.
Apr 01, 2010 | LG Flatron L1919S LCD Monitor
Ho w can i get driver for my flatron touchscreen lcd monitor to activate his features
LG Flatron L 1510S LCD Monitor Drivers : Download from this website:
http://driverscollection.com/?H=L1510S&By=LG
open directly link and download from website, then install in your PC. Your problem will be solved
Jan 29, 2010 | LG Flatron L1510S 15" LCD Monitor
Black screen on my LG Flatron lcd 563le
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Bjorn
Jun 02, 2009 | LG Flatron 563LE 15.1" LCD Monitor
Hi for all,a nother LGflatron LCD 563le problem
hsonic75, You need to do the flashlight test the next time your LCD goes to a black screen. Make sure that PC is fully booted with a Windows Desktop showing. then reconnect the 563LE to PC. Turn on the 563LE and note how long it takes to go dark. After you get dark screen, shine bright flashlight at different angles close to screen. Do you still see a faint image of the desktop? Let me know results of test. How old is this monitor? Is it covered by a warranty? Have you called LG (Lucky Goldstar) to find out if they have a swapout program? You send your monitor+$40-$90 and they ship you a same model REFURBISHED(with new CCF tubes/SMPS/INVERTER boards) back to you. Your complaint sure sounds like an INVERTER or Switch-Mode-Power-supply problem to me! All you need to do is a search on net for: 'bad caps in lcd monitors' or 'bad caps on lcd boards' and you will be inundated with more than you need to know! I'm louie12fix on fixya or lmistyrel@ aol.com
Bye for now.
Apr 15, 2009 | LG Flatron 563LE (White) 15" LCD Monitor
My lg flatron 563le monitor is a bit brght
auto on the front will usually fix this however theOn Screen display has a brightness setting and its straight forward,
Mar 22, 2009 | LG Flatron 563LE (White) 15" LCD Monitor
LG L194WT Monitor suddenly stop working
it is probably indicative of a switched mode powersupply trying to start then seeing a short and then trying to start again...this will cycle continuously until fault is rectified..any component that can drain the powersupply is the culprit...you need some way of detaching the powersupply from the load (monitor) to see if the power supply its self is the cause and also check if there is a loop back (a pulse) for continuous running.
qube
Jun 06, 2008 | LG Flatron 563LE 15.1" LCD Monitor
LG Flatron 563LE 15.1" LCD Monitor Logo
360 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
