Question about Pioneer PDP-4350HD 43 in. Plasma Television
Pioneer PDP R06XE Switch on, wait ages, then the blue light starts to flash, tv comes on for a second then cuts out again. (Not every time, sometimes it comes on straight away, other times it can take 2, 3 or more attempts)
  • 4 Answers
SOURCE: pioneer pdp 5080xd
put a pack of smokes direcly in front you wont see the lite anymore
Posted on Dec 14, 2007
donutty
  • 22 Answers
SOURCE: pioneer pdp-v402 40"
http://www.utram.com/medias/Ecrans_Plats/pioneer_PDP-V402_doc_eng.pdf
Posted on Jan 12, 2008
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
Posted on Mar 17, 2009
tvservice306
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
SOURCE: My pioneer pdp-505pg tv won't turn on
Hi! I have the same problem, did you solved it? I'm from Brazil, and i have the same plasma display, the customer suport of here, sayed that the problem is the power suply board. I saw that you changed the power suply, where did you found it? I didn't found it here, and i will travel to USA.
Thanks!
Posted on May 12, 2010
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
I have a PDP-r06xe conected to a plasma, when i switch it on, it switch off byself and the blue led blink eight times. what can be the problem???
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hoping this will help solve the problem of the television.....
Jun 23, 2011 | Pioneer PDP-4350HD 43 in. Plasma...
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
Feb 06, 2011 | Pioneer PDP-4271HD 42 in. Plasma...
WHEN ON STANDBY WHEN TRY TO SWITCH ON BLUE LIGHT COMES ON BUT AFTER A FEW SECONDS FLASHES HAVE TO ATTEMPT MANY TIMES TO SWITCH ON ALSO SOMETIMES WHEN TRY TO TURN VOLUME UP OR CHANGE CHANNEL SWITCHES OFF TO...
Hello, Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 02, 2010 | Pioneer PDP-427XD 42 in. Plasma Television
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Nov 18, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Pioneer PDP 436XDE
hi there, you have to send if for repair, tech people knows the prob., there a defective part to replaced. do some test and check up at the horizontal and power supply section. ty
Feb 18, 2008 | Pioneer PureVision PDP-4300 43 in. Plasma...
Plasma turened off and red light flases twice
Red flashing x2 = Panel power supply fault
It would be easier to replace the power board than attempt a repair at component level (dangerous voltages)
Oct 13, 2007 | Pioneer PureVision PDP-504HDE 43 in....
Pioneer PDP-4350HD 43 in. Plasma Television Logo
166 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
