Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman DLT 3000 riding mower. About 3 years old. Two things: When I pull the lever to engage the blade(s), the deck gets stuck or feels hung up and then suddenly the blades engage. Pully or belt issue? Also, the cut seems very uneven and the deck maybe off balance or the blade bent. Thoughts?
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 133 Answers
SOURCE: Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Posted on Aug 13, 2009
  • 138 Answers
SOURCE: deck is leveled, blades are fine,spindle not bent it still cuts
there was a problem with the lighter gauge decks [thinner steel], and the deck would actually bend inward on the left side. this would tilt the mandrel inward making the blade cut at a slight angle to the right blade - there is tool to straighten the deck [the left mandrel housing usually breaks, though] - some shops have this tool, others have never heard of such a thing - most sears l&g field techs have this tool in their trucks - i have the tool in my shop, but i have had luck with turning the deck over and whapping it a couple of times on the inside edge of the left mandrel until the blades line up
Posted on Aug 26, 2009
  • 138 Answers
SOURCE: 2003 DLT3000 Craftsman riding mower. Air in tires
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
My Craftsman DLT 3000 Riding Lawnmower will not go into gear.Could something have come loose? a spring orwire to the mower?
At the rear of the mower at the very back is a transmission disingauge lever, it may be set, this lever is so u can easily push the mower when it is not running...!
Oct 26, 2014 | Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
How to fix a PTO (blade engager) lever on craftsman riding mower 2000LT
cable is broken down by the deck... most likely
or it is broken by the handle... also most likely
belt engagement arm is stuck... also likely
Aug 29, 2014 | Garden
My YTS 3000 will run but the blades won't engage. Engagement lever is really hard to push up but when I try to engage blades, nothing. Could it be the cable?
Find where the cable is connected to the deck. Have someone move the lever and watch the end. Does it look rusted or bent?
Unclip the cable at the deck. Then try the cable. If it moves freely there is something rusted, bent or broke on the engage pulley mechanism on the top of the deck.
Nov 02, 2013 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
Craftsman 25 Hp with 46inch deck. The blades will not engage when the pot switch is pulled
one of 2 things keyway sheared off on the engine pulley or saftey switch on the lever to engage has shorted out
Jun 29, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower LT3000 blades won't engage/turn
Well, we wouldn't want to lose your little girl, but goats can be very lovable.
The problem could be it just needs lubricating. I'd first spray WD-40 on every part of that mecanism which moves, top to bottom, even inside the button on top and underneath the deck.
If that doesn't work, get back to me, please.
May 09, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
179 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
