Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice Maker problem
Ice maker appears to over-fill, making ice cubes too large and not duping properly. Is there an adjustment to make smaller ice cubes?
  • Anonymous Mar 19, 2014
    Ice cubes overflowing. Arm of ice cube maker came off. How do we reattach arm?
    Genius:
  • 1,073 Answers
Remove the cover on the frount of the icemaker and on the right side of the module there is a little and i mean little white adjusting screw, turn it clockwise 1/2 half of a turn clockwise and this is what adjusts the fill time of the ice maker, you may need to adjest back and forth to get the desired size of cubes but do not go more that one complet turn of the screw to get the size
if you can not get it by doing this then the frount module will ned to be replaced
Posted on Apr 20, 2008
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Hoshizaki km151bah ice machine not making cubes. ice is coming out in one big sheet. Why?
The depth setting on the evaporator cube setting may be set too thick making the cubes stick together. Adjust it to make smaller cubes.
Feb 28, 2015 | Hoshizaki KM-151BAH 121 Pound...
Water leaking than freezing on floor of lower draw under ice maker in subzero 700tf freezer
If cubes are very large the ice maker may be overfilling and need the fill adjusted to allow less water into the maker. Otherwise check the fill tube (runs from the back wall to ice maker) for loose connections or cracked tubing. (In this instance the cubes would be smaller than usual.) If neither of these is the source, then look up to the highest point of ice (water flows downhill) for the origin. Suspect a stopped up defrost drain. Thaw and clear ice, then clear drain tube (DO NOT use a wire for this) with warm water and a turkey baster. Once water is flowing through tube and into drain pan under the unit the problem should be solved.
Dec 05, 2014 | Refrigerators
Ice maker over fills with water
pull the front cover off the ice-maker its self and you will see an adjusting screw on the L/H side. This is where you adjust the size of your cubes. Make the cubes smaller.
Sep 28, 2014 | Frigidaire Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
I have what appears to be a water leak of some kind in the freezer section near the ice making part of the freezer. You can tell because the freezer is building up ICE all around the bottom of the ICE...
Check to be sure your ICE door chute is closed or closing properly! I have encountered many of these units that have had the flap break off the mounting tabs inside the dispenser opening. If the flap appears to be intact, I would next guess that your ice maker timing is allowing the ice maker to over fill and spill water into the ice bucket.
You can confirm this problem by looking at the ice maker and seeing if the ice cubes in it are filled right up to the center bar that drives the cubes out of the mold.
Let me know if you have any more questions!
Thanks, BOB
Aug 18, 2010 | KitchenAid KSBP25FKSS Side by Side...
I have a side by side that has the ice maker in the door, when it makes ice cubes, they come out all connected and this makes it difficult to get ice to despense from the shoot and most of the time it will...
It sounds like you have too large a fill of water in the ice maker. If you remove the ice maker there is a fill adjustment screw under the cover of the ice maker.( the only way to get the cover off is to remove the ice maker)
Very small plastic screw head of about 1/8 inch or less. Ice maker controls water valve by time fill. Believe there is one turn adjustment total available. You might want to put a small hole in the cover before you reinstall it to adjust screw the next time without removing ice maker, believe it will be side facing out. Lastly I think you turn adjustment screw in to decrease and out to increase time of fill.
Suggest leaving a towel on the floor for awhile until you have solved problem.
Next thing to try would be a different ice maker, or if normal sized ice is melting and refreezing in the bin, you have a cooling or thermostat problem .
Good luck
Mar 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The cubes are hollow and keep get stuck when they try dispence
The cubes are hollow? Means not enough water coming in on the fill cycle to fill the metal ice tray (netal form, see solution #2). There should be an adjustment under the end cover, looks like a screw with a spring around it. Look inside the cover and see if the directions are there for adjusting it properly.
Sep 19, 2009 | Whirlpool GD2SHGX Refrigerator
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
526 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
