Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Wavy lines on panasonic rear projection tv
Tried convergence, works fine but have wavy lines which move around the sections of the tv
  • 10,515 Answers
This is a convergence issue. By making adjustments in settings, this would not solve the issue. You need to change the Convergence IC.If you want to repair it, revert and i would be glad to guide you.You need to have electronics experience, should know to read schematics ( if required ), could use multimeter and soldering iron.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 17, 2010
  • fredscafe Jul 23, 2010
    we don't have that kind of experience. soldering yes, some electronics yes
  • taran_2005
    taran_2005 Jul 23, 2010
    Thanks for your response!!
    **Please understand that by opening a TV you are exposing yourself to many dangers, including electrocution. Be sure that the set is un-plugged and keep one hand behind your back whenever possible to avoid a shock through the heart as this CAN KILL YOU. If you have zero electronic experience I would not attempt this repair.**
    OK, public service announcement over.
    The components that do that job are called "convergence" circuitry. The usual components to fail are the "Convergence Amplifiers" which are usually a pair of Integrated Circuits mounted to a large heat sink. (STK-392 or STK-394) may be printed on the IC along with some number such as 110, 160, 120.
    Below is s a walk through on a Mitsubishi, this applies to Panasonic as well, they all use the same chips and circuits, you will at least be able to see what is involved in the repair.
    http://www.techlore.com/article/22530/DI...
    Also look for burnt resistors around these components, as it is common.If the problem is isolated to only one color the replacing those STK amps and any burnt resistors will fix it. If all the colors are out of whack (Red, green, and blue, like a 3d effect all over) then you are likely looking at a fuse gone bad in the voltage supply to those amplifiers. Usually Sony or Mitsubishi have these fuses. The fuses (called "pico-fuses") are generally orange, or green, with no color stripes like resistors have.
    You can look up these parts online easily with the exception of the burnt resistors and fuses which you usually need a manual(which you can also purchase online). The STK's price will vary from $15-$90 depending on which one, and the resistors have to be of the metal oxide type so as not to change value with heat.
    One place to get parts is www.partstore.com
    You could also get the IC's from even radioshack or Fry's.
    If you want a professional to repair it, be prepared to part with around $300-$400.
    Let me know,if needed further assistance.
    Hope i helped you.
62" mitsubishi tv wavy picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The picture of my tv is distorted and wavy. i can see that there is an image but can't make it out very well.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Toshiba 42H81 42" Rear Projection...
My tv looks like it is in 3D without 3D glasses,
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith R45W46F has sound but no picture
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2010 | Zenith R45W46 45" Rear Projection...
Componants in back don't seem to work, HD cable,
*Screen Looks 3-D
*Colors wont align
Oct 22, 2009 | Philips 55PW9363 55" Rear Projection...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic projection tv
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic hdtv pt-56wx42
  • Screen looks 3D
Dec 01, 2007 | Panasonic PT-56WX42 56 in. Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
234 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
