Question about Samsung DMR78AHS Builtin Dishwasher
SE error message
Received the SE error message. Checked drain tube and inside the dishwasher. All appears clear. Disconnected the tube from the disposal and ran the rinse cycle. The dishwasher drained and there does nto appear to be any blockages in the tube. Re-ran the "QUICK" cycle and it rinsed OK and when it started into the wash cycle it stopped and flashed the SE light. Checked the inside and the "self-dissolving" packet of detergent kept the door closed. Removed it, left the detergent compartment open and re-ran the QUICK cycle. This time it went through the RINSE and WASH cycle. then it stopped and flashed the SE error message again. Can't figure this one out....
  • 11,896 Answers
You didn't say, but is the drain hose connected to a garbage disposal? If so, is the knock-out removed?
Is the pump running or trying to run? Any kinked houses internally or externeally? Is the pump or screens plugged? Does it work without detergent?
Posted on Jul 11, 2010
How do i fix an SE error code on my Samsung dishwasher
The SE or 5E error code means "Draining Error", which coincides with what you observed. First check the drain hose for an obstruction, especially where it goes into the garbage disposer (and check the garbage disposer port to make sure it is clear too). If that's okay, then you will have to pull the dishwasher out to check the drain pump. Chances are, some foreigh object has gotten into the drain pump, and is blocking or partially blocking the water flow. If everything is OK, then you probably have a bad ECS sensor, and will have to replace it. If most of this is beyond what you want to do, at least check the hose at the garbage disposal end before you call a repairman.
Feb 10, 2015 | Samsung DMT800RHS Dishwasher
Kenmore dishwasher 665-15805890 parts
If the dishwasher is connected to a disposal, there is a knock-out on
the disposal inside the stub on, a screwdriver will remove it. Catch it
so it will not go in the disposal.
May 12, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
Maytag dishwasher will not drain
Drain Tube could be clogged....Have you disconnected the outlet drain tube from the motor to the disposal/sink/drain?
Aug 11, 2010 | Maytag MDB5100A Dishwasher
KitchenAid KUDR24SE dishwasher doesn't drain.
check the drain tube at the disposer
Jul 02, 2009 | Dishwashers
Dishwasher
if you installed a new garbadge disposal at the same time have you popped the factory drain plug on the disposal where the dishwasher drain tube connects to the disposal. The plug is inside the disposal dishwasher connection tube . You cant see it . Just drive a screw driver through it with a hammer.Itt will pop out and then the dishwasher will drain.Just a thought.I forgot to do this to mine.
Mar 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher not draining
remove the clamp holding drain tube to disposer, unplug disposer, and see where clos is its gotta be right there, UNPLUGGED.UNPLUGGED you can stick a screwdriver thought drain hole in side of disposer to clear debris
Feb 22, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Samsung DMR78AHS Builtin Dishwasher Logo
202 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
