Hello I have a Technics SL-BD22 i bought it in 1992it still plays fine but recently I decided to buy a better cartridge(ortofon omp 10) so i could get a better sound quality from it and i noticed that on the most of the records the last track from both sides of the records donĀ“t have a sound quality as good as the other tracks from the begginning. The last tracks usualy have a sound slightly distorted. my question is what sort of up grade can I make on my turtable to solve this problem and can have the same good sound quality from the begginning till the end of the records? do I have to replace the tonearmT4P or is it enough to buy a better cartrige and what cartrige would be better suitable for my tuntable. If you can hellp me whith this issue I would thank you a lot. thanking you in advance carlos Sousa
djproaudio
  • 515 Answers
SOURCE: record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Posted on Apr 21, 2008
djproaudio
  • 515 Answers
SOURCE: technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
Posted on Jul 12, 2008
djproaudio
  • 515 Answers
SOURCE: problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Posted on Jul 23, 2008
  • 104 Answers
SOURCE: new cartridge for Technics SL -BD22D
the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
Posted on Feb 11, 2009
SOURCE: Technics SL-BD22 ground wire does not reduce hum. Any solutions?
I have found out that the female phono plugs on the turntable are sensative and have to have a solid connection and often adjusted from time to time to eliminate the 60 cycle hum.
Posted on Nov 04, 2010
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
Trying to track down a tonearm plug in connector and stylus for an SL-BD22. Is it possible to get the connector separately? Can you recommend the best place to get them?
Hi, Is it the headshell you want like this?
If so I have 1 in stock $39.90 USD. I also have an original Technics EPC 24 P mount cartridge with stylus which were fitted to SLBD series $49,90 USD. Cheers John. styluscity@gmail.com
Nov 10, 2011 | Technics SL-BD22 Turntable
WHEN I TRY TO USE ANY ORTOFON CARTRIDGE I GET FEEDBACK WHEN I PUT IT ON THE TONEARM BUT ON MY TECHNIC 1210 IT DOESNT HAPPEN BUT IF I USE ANY STANTON CARTRIDGE IT IS FINE? WHY WOULD THIS BE? ALSO THE...
I'd fix the tonearm issue first before using it to decide you have a feedback-related issue with one brand of cartridge. I can't say how that would be fixed.
Feedback? Like airborne sounds from the speakers vibrating the turntable and being amplified through the speakers? The biggest downside to old-school vinyl use is that possibility and the workarounds we had to use to prevent it. Acoustic and physical isolation are the only solutions.
Apr 22, 2011 | Technics SL-1200MK2 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
Cartridge
"at3482p-de" <--do a search for this at yahoo. the resulting cartridge is correct for your model. it comes with the needle as all cartridges do. There are better ones you can get but this one is aprox. equal to the original supplied with the unit. In short any pmount type cartridge will fit/work in your player.
Jan 29, 2009 | Technics SL-BD22 Turntable
Technics sl-ql 15 linear tracking T/Table
www.lpgear.com
- DAVIS
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
Turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
May 12, 2008 | Technics SL-1200MK2 Turntable
51 people viewed this question
 Grubhead
Grubhead
