Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
I have a Frigidaire Gallery Side by Side Refigerator FRS262GH. My ice maker has stopped working. There is no ice or water in the ice maker and the arm is stuck mid way up..it will go all the way up but will not retract down. And I have not had ice in a week. The ice makerlarge screw turns to have ice come through the door but the freezer is not making ice. I have used a blow dryer on the coils inthe back thinking they were fropen and turned down the temp in the freezer thinking it got too cold but to no avail. I have also turned off the refigerator(unplugged) it thinking maybe a computer circuit malfunctioned and needed to be restarted but that hasn't seem to work either. Any suggestions?
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
  • 833 Answers
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Posted on Dec 24, 2007
SOURCE: Frigidaire Refigerator
TEMP FIX i found remove hinge cover top of left door and unplug the Icemaker and fridge will run again havent figured out the problem with icemaker yet though
Posted on Feb 19, 2008
SOURCE: samsung rs2630hs
Well, it sounds like your condenser fan motor has seized up and needs to be replaced. I had the same problem and additionally it woudl onhly produce about twenty cubes of ice a day. Best Buy repair guy came replaced the fan motor and within 10 minutes the heat was dissapated from the strip and it started churning out ice agin.
Posted on Apr 22, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
We have a side by side refigerator and it stopped making ice. I thought it may have been a dirty filter because I unscrewed it and there was ice surrounding the filter so I replaced it today. I am getting...
If the ice maker switch is in the on position then It sounds like the electric solenoid valve that controls the water flow to the ice maker has failed. Have it replaced and that should fix it. Hope this helps. Good luck.
Dec 02, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Jul 13, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
151 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
