Question about Oster 6710 In2itive Food Processor
Oster microwave omw 1160 won't turn off
Will only turn off when door is opened. tried pulling plug and waiting but no change.
I need instructions for my oster blender food processor
Try Googling (oster)(model)(manual) without parens.
Sep 08, 2017 | Oster Food Processors
Need a manual for my Oster regency controlled power kitchen
try google.com and search for make,model and manual
Mar 16, 2015 | Oster Food Processors
My bowl will not turn by itself anymore on my Oster Regency. How can i fix this problem?
Unplug electricity cord from wall and disassemble bowl carefully. Clean dirts on moving parts. Be careful not to leave any liquid on any piece.
If motor output shaft rusted; use some rust remover on piece of cloth and clean it. Be carefull; don't use too much rust remover and don't let it go into motor to prevent electrical shock. Try to turn output shaft by hand. If it turns easly assemble everything back again. If it doesn't turn that means; motor might has some issues. There is no way to fix it but changing motor with a new exact one.
Nov 19, 2014 | Food Processors
I need an instruction manual for a Oster Food Chopper FPSTMC3321
Oster has not made a manual for your specific model available online. The User Guide for the Oster 3320 3-Cup Chopper with With Attachment, which appears similar to your model may be of assistance. This User Guide may be downloaded here.
Jan 08, 2012 | Oster Food Processors
Oster 3200 processor but have no blade shaft and cannot find on line. Do you have or know where I can purchase one?
Hi there.
Try http://www.oster.com
You will be able to find authorized parts dealer near your area.
Regards.
Mar 28, 2011 | Oster 3200 Inspire In2itive Food Processor
On switch not working on my oster 3322 food processor
DOUBLE CHECK CONNECT THE MACHINE ON A ANHOTHER POWER OUTLET ,FI YOU CAN OPEN THE MACHINE ,GET MULTIMETER CHECK THE SWITCH FOR CONTINUITY ,,IF YOU HAVE CONTINUITY ON THE SWITCH THE MACHINE MOTOR PROBABLY IS BAD...
Feb 19, 2011 | Oster 3212SNB Food Processor
Have a sunbeam oster kitchen centre....mixer,blender, sausage maker...but no manual..1985 -86 model...help. #97108C ON MAIN BODY.It has stainless bowls, glass blender jug. Sure would love a manual.Thanks.
I have an Oster Kitchen Center by sunbeam. It has the mixer, blender and food processor. When I attach the processor to try to use it the blades do not spin. If I push the siler know down with an objest it will turn. Am I missing some little piece to make it work.
Sep 13, 2010 | Oster Food Processors
When i open the door only the light is supposed to come on. the light comes on but the fan and turntable run also.
This is a very hazardous condition. DO NOT stick you hand inside the unit as you may well get yourself burnd by microwave radiation. It appears that there is either a problem in your control panel assy or that you have time on your timer and the unit has a defective door switch allowing the magnetron to keep running with the door open. There are at least 3 protective micro-switches in the door closed and latched circuit. Very slowly depress your door open button or pull the door open slowly (depending on unit type) and listen for 3 distinct switch clicks. All 3 click should happen in less than one one half inch of the door opening. Try is sevral times and listen for the 3 clicks repeatedly. If you do not hear 3 clciks then you have a bad micro-switch If you hear all 3 clicks, more than likely your controll panel has a failed relay on it.
Jan 06, 2010 | Food Processors
Oster In2itive blender leaks
The three most common sources of leakage are a worn/damaged gasket, a cracked jar, or a cracked blade assembly - all of these parts are available from Oster. If you are still under warranty, they might even be able to send whichever part you need for free. Their phone number is 1-800-334-0759 (they are owned by Jarden Consumer Solutions nowadays).
May 19, 2009 | Oster 6710 In2itive Food Processor
No instruction manual for Oster 500 watt 3200 Food Processor
http://www.oster.com/manuals/oster/003200-000-000_English.pdf
you will need the free adobe acrobat reader if you dont already, chances are you do, I found this at oster.com
Mar 30, 2009 | Oster 3200 Inspire In2itive Food Processor
Oster 6710 In2itive Food Processor Logo
182 people viewed this question
Top Oster Food Processors Experts
Angel Joseph Jr.
Angel Joseph Jr.
ray gallant
Are you an Oster Food Processor Expert? Answer questions, earn points and help others
