Question about Skil 2887 05 18 Volt 2 Speed 3/8 Inch Drill/Driver W/Bit Index, 2 Batteries, Charger & Case
My battery will not charge
Is there any way to fix my self?
  • 2,100 Answers
Supposedly there is , But I don't think so, There is a video on you tube that shows somebody messing with them, I think it is a bunch of ****. Is it the battery or the charger? Do you have other batteries that charge up? The life of the battery is about 1 year. I have boxes full of dead batteries, and guns and chargers. It is cheaper to buy a new gun with batteries and charger than it is to buy 2 new batteries. Check it out.
Posted on Jul 11, 2010
Psp wont charge or tunr on
Did you put the battery back in? Just checking. This sometimes happens with the PSP's. The charger it's self looses the ground. Try plugging in a car charger, or use a charger that will charge the battery out of the PSP.
Feb 15, 2014 | Sony PSP-2001
My 1999 ford wind star won't start after trying to install a stereo my self battery says its fully charged
check all fuses then the ignition module with a timing light then the fuel pump one of these will fix the problem
Feb 04, 2013 | Cars & Trucks
Self start problem
Your starting problem may be battery charge level. Take buy a auto parts store, most will measure the battery charge condition and may recommend a new battery, They will also measure the status of the charging system, which if not adequate, will contribute to the poor battery charge and starting problem. If the battery condition is good or very good, you may have a Starter solenoid or starter and solenoid problem.
Feb 28, 2012 | 2001 Maruti 800
I have a 1994 dodge dakota and it is back firing bad through the exhaust and will choke it self out if throttle is held in one position. the truck will lose power if driven and choke it self out and the...
The definition of code 45 nis "CHARGING SYSTEM VOLTAGE TOO LOW".
To put it plain and simple, It is trying to tell you that your computer is starving to death.
This could be due to a shorted battery, a bad alternator, bad/corroded battery cable connections or a combination of these things. Fix your charging system and you will most likely fix your engine running problem.
Please also review this article:
NOTE: The title does not match your description of the problem, but the information contained in the article does.
My Car Won't Turn Over
Aug 28, 2011 | Dodge Dakota Cars & Trucks
Self charging problem on sonyericsson k800i
check the voltage on the battery contacts, check the charging voltage on the battery terminals of the phone,if low replace adaptor.
If Ok then replace battery and charge, if the battery does not retain the charge then replace battery as it might have developed reverse polarity. If adaptor is ok but charging voltage at terminal is low , check the mother board.
Sep 30, 2010 | Cell Phones
Nokia N73 not charging. There is no issue with battery as it is working in other cell phone. I have also tried different chargers. The problem seems to be with point where the pin is inserted.
hello,
this means that your phone have develop charging port problem, that is the charging port is bad
what you have to do is to replace it with another that is of good condition
you can do the fixing your self if you have the tools to unscrew phones get a new charging port from the store unscrew your phone remove the bad month pics and fix in the new one you but from the store
note if you can't do it your self take it to a very good phone work shop around you to do the fixing for you then you will be able to charge your phone from it own charging port again.
thank you and thanks for using fixya.
Mar 29, 2010 | Nokia N73 Cellular Phone
Cannot charge new battery
Battery is not a known issue for this model, However 3rd party batteries causes some self discharge issue. Make sure the battery is not defective. The little charge circuit on the battery might have different threshold voltage also. Normally battery should show around 4Volts when fully charged. After save your data try full reset and complete discharge of the battery and try again
Good Luck
Jul 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
New battery and charger, but still not charging
Not at all. take battery and laptop to store for proper chack.
Good luck.
Rate this
Apr 13, 2009 | HP Pavilion dv1000 Notebook
Skil 2887 05 18 Volt 2 Speed 3/8 Inch Drill/Driver W/Bit Index, 2 Batteries, Charger & Case Logo
258 people viewed this question
Top Skil Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Skil Air Tool and Compressor Expert? Answer questions, earn points and help others
