Question about Vizio L32 32 in. LCD HDTV
32'' Vizio won't work
Bought TV less than a month ago. Worked OK until 7/10. Now when it's turned on it goes off in about 2 sec. Tried unplugging it for a while, no change; tried unplugging it and holding on/off switch for 30 sec. No change. In process of doing various things with TV I moved the TV and it came on for 2 sec then off again. Seems to me I've got a lemon with bad component. ???
  • 11,361 Answers
It is under warranty, I would take it back and ask for exchange, bad sign that it goes out in less tahn 30 days.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 11, 2010
My t.v display and sound will not turn on after the t.v has been turned on.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 21, 2012 | Vizio 32" E321mv 1080p 60 Hz Lcd Led Razor...
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
32" VIZIO PROBLEMS
The main board is bad. I have seen a lot of TV has the same problem like you have. Replace main board will fix it. If you bought these TV from Costco and less than 2 years then they all still under warranty.
May 05, 2009 | Vizio L32 32 in. LCD HDTV
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Nov 26, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio VX37L 37'' LCD HDTV Television not turning on
Unplug set and hold and press the power button for about a minute. Replug set and turn it on. If nada, then the issue is with the power supply of the set. Given its age and the high cost of repairs it might be more cost effective to get a new set.
May 03, 2017 | Vizio L37 Television
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
138 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
