Question about Roxio Easy Media Creator 10 Suite
Disc I have Creator 10 Suite, It will not recognize my Disc Drive
    President:
  • 2,571 Answers
It may be a conflict with another program. Roxio is a little tempramental about other software.
You can try another Burning software to check the drive is not faulty.
You can try a free program like IMGburn.
If that program works i would uninstall roxio, run a registry cleaner. I like CC cleaner's built in registry cleaner.
Then re install roxio and check the roxio site for any updates
Posted on Jul 11, 2010
Cannot burn dvd's hard drive is too low on memory how to fix this?
from my computer see your C, it is full, move your files from C to D, or burn its on disc.
Jun 13, 2011 | Roxio Easy Media Creator 10 Suite
I purchased Roxio Easy Media Creator 10 and loaded it into my tower and nothing happens-- I have done this three times and still nothing happens--is there something wrong with my computer
click on my computer then you will see the disc in drive d/e yes put the mouse on it and right click the mouse 1, this will open a plane scroll down and click explore open it and look for the install application then double click it.... this should work
Jan 16, 2011 | Roxio Easy Media Creator 10 Suite
I am receiving error code 0643 when I try to install Roxio Creator 2010 Pro and then program uninstalls.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall your software.
Jun 11, 2010 | Roxio Easy Media Creator 10 Suite
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Cannot load easy creator 10 onto vista
i Think you do not have vista compatible softwares i.e.
Roxio Easy Media Creator 10 Suite . So please buy vista compatible software or path with vista patcher . You can easily download vista patch from www.rapidlibrary.com . Patch and run the software in vista. Best of Luck.
Nov 06, 2009 | Roxio Easy Media Creator 10 Suite
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
Roxio Easy Media Creator 10 Suite Logo
124 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
