Have a Hoover Nextra 8 hnf 7148 washing machine - can't find the manual - but the fabric softener is not being used during the wash - this has been going on for a few weeks now. I've taken out the dispenser and checked it's not blocked and cleaned out (several times!) but still not being washed away - any thoughts?
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
Trifect7
  • 57 Answers
SOURCE: hoover nextra hnf 3671 -
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord if you feel qualified.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Posted on Mar 02, 2008
SOURCE: Water leak at rear of
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Posted on Jul 30, 2008
  • 5 Answers
SOURCE: Fabric softener won't dispense
Have you tried thinning the softener with water? It's what I used to do on my older washer, it wasn't the new Duet, but it seemed to help. Hope that helps. (PS I don't use softener anymore as I have developed a terrible skin allergy to these newer longer scented softeners! )
Posted on Jun 20, 2009
  • 574 Answers
SOURCE: hoover nextra washing machine , not draining
take pump off and take apart to clean
Posted on Aug 28, 2009
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
