Question about Northstar Pressure Washer 3000 PSI
I have a NorthStar M157471A. What weight oil goes in the pump?
  • 700 Answers
I just answered that question on another thread... will repeat:
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Posted on Aug 16, 2010
What kind of oil replaced the Harley Davidson type "c" oil fork ina SS Sprint 350cc?
Fork oil is the same as hydraulic pump oil. Depending on your preference choose a light weight oil, 5-15 will give a soft ride. As the weight numbers go up the comfort level goes down. However, the heavier weight oil provides better handling. A bit of experimentation will varying weights should be considered for the optimal combination of ride comfort and handling. One final note. Always. Purchase a non-detergent oil
Nov 21, 2015 | Harley Davidson Fork Oil
What kind of oil does a northstar model # 157550b take
THATS A HONDA ENGINE , SO IT TAKES Honda 08207?10W30 IN THE ENGINE AND STRAIGHT 30 WT NON DETERGENT IN THE PUMP OR YOU CAN BUY IT RIGHT FROM NORTHERN PUMPS SUPPLY AS WELL
ALLWAYS CK PUMP OIL WHEN FILLING GAS TANK AS SOME MINOR OIL LOSS IS NORMAL ON USED PUMPS AND IF OIL BECOMES WHITE LIKE MILK THEN IT NEEDS REPLACED RIGHT AWAY (WATER CONTAMINATION ) IF OIL USE GOES OVER 1 QT FOR EVERY 12 HRS OF USE THEN PUMP NEEDS REBUILT
Nov 11, 2015 | Cars & Trucks
ALTHOUGH MY DIPSTICK READS FINE, WHENEVER I PUSH ON THE BRAKES, MY OIL PRESSURE GOES DOWN TO 0 AND MY CHECK GAUSES LIGHT COMES ON
I would say that you are definitely low on oil pressure. The oil pump is usually located inside of the oil pan. Depending on what vehicle you have you might have to have the engine removed to access the oil pan to get to the oil pump. I know on a Cadillac Northstar engine you get 43 hours to do an oil pump.
Jun 05, 2015 | Cars & Trucks
What oil weight is used in the pressure washer pressure unit
Non-detergent 20-30-weight goes into pump port, and is filled about half way.
Ordinary motor oil 10-W30 or 40 goes into engine port.
Nov 11, 2012 | Dewalt Gas Pressure Washer: 4200 psi 4.0...
I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
May 09, 2011 | Northstar Pressure Washer 2800 PSI
Oil in sightglass on pump is low, what type of oil goes in it.
In the absence of any instruction manual, you can safely go with any good quality SAE 30 motor oil.
Jan 22, 2011 | Northstar Professional Series Pressure...
Hi, please can you tell me what is the different between the 1993 northstar engine's oil pump and 1998 northstar engine's oil pump? thanks in advance
If I remember correctly it has somefhing to do with capacity. The best way to find out is check with a GM dealer to see if the part number for a 1993 is the same as a 1998
Aug 30, 2010 | Cadillac STS Cars & Trucks
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Northstar Pressure Washer 3000 PSI Logo
111 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
