Question about Nintendo NES Console
The system has problems starting up the game and will crash sometime after it starts working.
    Sniper:
  • 78 Answers
It is likely the contacts need to be cleaned on either the game cartridge or the NES itself. There is debris or dirt on the contacts which explains the erratic behavior. .
Posted on Jul 11, 2010
My favorite game Heroes of Newerth start crashing suddenly on my computer.. i have tried few fixes but its not working.. help me :-(
It's likely conflicting with some recent change in your software. You may want to go to a system restore point previous to when you first started experiencing these problems.
Jul 13, 2011 | Video Game Consoles & Games
When i click on training it causes a crash dump
here are instruction to fix crash dumo to your sega football manager 2011
Step 1shock.gifpen up your steam
Step 2: Go onto your games list
Step 3: Right click on Football Manager and select properties
Step 4: Select the Local files tab on the far right
Step 5: Click the option Verify integrity of game cache
Step 6: Click the option Defragment game cache
It should now be complete
this worked for me
I'm sure there are other people out there who have had there game destroyed by Crash Dumps errors, sometimes screwing your save, sometimes even preventing you from starting new games forcing you to re-install only to come across the same problem later down the line.
So here is my 2 part guide to Crash Dumps, part 1 is how to set your game up to minimize the chances of your game ever getting this error, and part 2 is what to do to recover your save (If possible) and get your game back to a working state if you had this error already. Part 1 pretty much lists all issues that cause Crash Dumps and to set your self up to prevent it from happening.
Crash Dumps Prevention
There are certain things that increase your chances of getting an error, here is a list
1) FMRTE - Just dont go there, it screws your data base up beyond repair, you will not be able to get your corrupt save back if you have used this editor. Sometimes its been to known to cause damage to your windows registry too, unless SI make an official in game editor, using third party programs like this is all to risky stay away.
2) Size of Game - Even though I believe I have found the solutions to 99% of crash dump issues, it does not change the fact the game is not without major issues, the games coding causing endless memory leaks that lead to Crash Dumps errors.
So what I'm saying is try to go easy on your database size, either slow or at most medium size data base when starting a new game.
Also dont go crazy with the amount of leagues you select to be playable, if you have a good system 10 leagues at max.
If you must have lots of leagues and large data base I recommend you have at least 6GB of DDR2 or DDR3 ram, if you have an older system DDR ram will not cut it for crazy data base sizes.
3)Everything Up to Date ? - Make sure the following are up to date
+ Graphics Card Driver (Use manfactures site, sometimes windows will not find the most up to date driver)
+ Java - Make sure you have the latest Version
+Direct X - Latest Version your system is compatible with
4) General Settings in Game These are optional but I recommend you use these settings to prevent errors.
Uncheck the following boxes
+Use Skin Cache
+ Enable Data Collection (This is an important one, it will stop FM constantly building up the RAM useage and prevent Crash Dumps)
+ Play in Windowed Mode, Minimize, and Maximize Every Hour.
+ Disable sounds, and 3D cameras, the 3D sucks anyway text all the way.
+Play with Autosave weekly, 3 file rolling save for back ups, better safe than sorry.
+ Uncheck Threading, if you have a Dual Core processor, you do not need this to be checked, it takes away a complication. However if you have one processor with Threading technology keep it ticked, other wise the game performance will be poor.
5) Your Hardware Before Playing FM 2010 you need to be confident your hardware is all fully working, so you can rule that out if you need to trouble shoot in case you get the Crash Dump.
Consider and do the following before installing the game
+Power Supply - Is it at a high enough Voltage for my Graphics card ?, find out and upgrade power supply if need be, you should not be using a Graphics card if your power supply is under the recommended amount, your system will become very unstable, let alone Football Manager.
+Hard Drive Error Free, run Chkdsk, a windows tool to see if your hard drive has any errors.
To run chekdsk press the windows button and R, then in the run box type in CMD, the in the black command box type in chkdsk and press enter.
You should have a report of no errors, or windows will fix errors
+ Faulty RAM - This was the culprit for me, run a program called MEMTEST86, you need to download and Burn it to CD, restart your PC with the CD in the drive and let it scan.
If you are error free all good, if not note which RAM slot is reporting errors, remove or replace that RAM.http://www.memtest86.com/
+Dust Bunnies - Your system would be unstable in general if you have these, if it is a little unstable check the innards of your PC for obvious dust, blow to free dust from sensitive areas.
If you ever get Blue Screen errors while browsing, gaming, multi tasking, then Football Manager will certainly Crash Dump you ***.
Okay if you follow all these steps prior to installing your game you are very unlikely to get the crash dumps error again.
please rate me if this help you thanks...
Jun 05, 2011 | Sega Football Manager 2011
Screen freezes and turns pink sometimes during game play
This is a precursor to a bigger problem. If this just started and you have an older Xbox, you should start to expect game crashing and potentially the Red Rings of Death. Try to clear your system cashe and play a different game. Otherwise, expect more problems.
Oct 28, 2010 | Microsoft Xbox 360 Console
Computer crashes
This could be one of many different problems. When did this actually start? It could be a problem with the power supply, it could be a problem with the motherboard or cpu, there could be a problem with the actual operating system itself. This is the steps i would recomend
1) Format and Reload your os and drivers etc, if this doesnt work move to step 2
2) Change the power supply to a new one or a computer that works. Borrow one from someone so that you dont have to pay for it only to disconver it isnt the problem
3) Do the same with your expansion cards
4) Do the same with your cpu
5) Do the same with Motherboard
Somewhere down the line you will know what your problem is and that is the part you will have to replace
Apr 30, 2009 | HP Computers & Internet
Crashing comp with nvidia geforce fx 5200
your agp video is overheating, see if the cooking fan attached in it is working fine.
Oct 27, 2008 | Nvidia Geforce FX 5200 Graphic Card
Computer Crashing during Starcraft Video Game
go to www.foxconn.com and see if you can find any upgrades on any drivers for your motherboard if there is download them and see if that works if not see about upgradeing to higher memory
May 02, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Keeps freezing/crashing
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Jan 26, 2008 | Nintendo Wii Console
Nintendo NES Console Logo
77 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
