Question about HP Pavilion tx1000z Notebook
The past couple of days my laptop hasn't been starting up. When I try to turn it on all of the lights turn on momentarily but then go out.
    Problem Solver:
  • 13 Answers
Either GPU fail, or CPU, google for "Towel Fix"
Posted on Jul 24, 2010
Toshiba satellite L305-s5955 power turns Problem with the PC Laptops Toshiba satellite L305-s5955 power turns on, fan turns on. screen stays black. Will not power off with button. Power supply working....
Hello Kristi,
I'm not sure if this will work, but worth a try. It appears that your power up settings have got messed up somehow.
Put it all back together, batteries and charger. It will try to boot after a fashion. Just give it a couple of minutes to try and do what it should. If it still hasn't come on properly, press and keep pressed the on/off button until the laptop turns off (about 5 seconds). Leave it a couple of minutes then try and turn it on again normally.
After this, I'd need to be able to look at what's happening to help any more.
Sep 12, 2011 | Computers & Internet
For a couple a weeks my mp3 hasn't been turning
Hi!
Sometimes system reset helps.
Please check the "Troubleshooting" part of the manual.
Hope it will help!
https://manualsbrain.com/en/manuals/1023629/?page=51
Sep 04, 2017 | Samsung YP-U2JZW MP3 Player
1996 LeSabre custom won't start. Turned key to start and lights on dash came on, car cranked momentarily the all lights on dash and entry went out and not a sound when turn key to start. This happened...
Make sure battery has a full charge and battery connections all good. Voltage and ground are both important. You could use a test light on the fuses in the fuse box to check for voltage. Some fuses are hot all the time, some go hot with the key on.
You may have to check feed to and from ignition switch.
Nov 02, 2017 | 1996 Buick LeSabre
My notebook won't turn on. When the battery's in, the green light comes on momentarily then goes off and the amber light comes on then goes off. When the battery's not in the only the green light comes on...
first, remove any external device as well as the ac adapter and the battery. while the ac adapter and battery is out, press and hold the power button for about 15seconds. then reconnect any power source and turn on the system. if it still doesnt turn on, remove memory, expansion cards, hard drive and optical drive then turn on the system. if it's still not turning on, the motherboard is faulty. but if it do turned on, reconnect the removed components one by one so you will determine which component is causing the issue. hope it'll help. good day. =)
Jan 07, 2010 | ASUS m6n Notebook
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
HP Pavilion tx 1000 Won't Start-Up
as a last resort,(or first, when I have laptop boot problems, is to unplug battery and power, and hold power button down for about 30 seconds, release, plug in and test.This Solves alot of laptop boot problems regardless of manufacturer. Hope this helps, if so thanks for any ratings
Mar 31, 2009 | HP Pavilion TX1000Z 12.1" Touch Screen...
I shut doen montor and it doesn't come back on
When you try to turn it on do you get lights ? Do you hear any noise like a high pitched noise coming from it ?
Make sure all the connections are secure ( I'm sure you have tried)
Try plugging it into another tower or on a laptop to see if the monitor is fine and the video card is not to blame.
Jan 04, 2009 | Acer Ferrari F-20 20" LCD Monitor
Toshiba 5205-S503 Laptop- No power
- You may want to try to reseating all neccessary things on the system like optical drive,hdd,memory but before you do that disengage the power from the system like the ac and battery.
-If no..go try to remove the optical drive first and then turn the system on, then if the system boot without the optical drive shut it down and put back the optical drive and boot to bios and load the default setting and boot the system normally.
Oct 11, 2008 | Toshiba Satellite 5205-S503 Notebook
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
