Question about Epson Stylus R265 InkJet Photo Printer
My mac won't add my printer
Can I ask you if you have any advice on my mac...I'm having printer adding issues.
ok I have installed it on my mac laptop (10.4.9 power pc g4).Ths printer is a fairly new model of a Epson photo stylus printer R265.
Now, when i plug it in via usb cable and into the power mains my computer defiantly recognises it however the problem lies in the adding it to the printer list.
i went to system preferences>print&fax>printing...i then went to 'add' . it registered the printer where it says 'printer name' box at the top. it also says the printer name in 'name' an in location it says 'power book'. that bit is all fine.
then..this is the bit which I can work out.
It gives me a list of printer models, none of which are the printer I have. When I go to 'other' i can't find anything which helps me.
So how do I add the printer is the question?! I'm a bit stuck!
I have a printer utility which from I can see how much ink is available, and also do a test print to make sure the cartridge print ok, and they do.
i tried old and new drivers too!!
Emma
  • Anonymous Jan 05, 2009
    this didnt work
    Genius:
  • 1,447 Answers
DRIVER REMOVAL
Note: If you have multiple printers on your system, you will need to re-add all your printers once this is complete. Please let us know what models you are working with.
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Restart the Mac. (You do not need to empty the trash.)
Download the drivers from this link R265
ADDING THE DRIVER PROPERLY
1. Open Printer Setup Utility. This would be found in HARD DRIVE, APPLICATIONS, UTILITIES. (Make sure your printer is powered on and connected at this point.) The "Printer List" window appears. Highlight and delete any existing references to your Epson printer. (If you want to be thorough and do not have any other printers on the Mac, choose "Printer Setup Utility" from the top of the screen and "Reset Printing System". Confirm resetting the system. This clears any existing printer entries and queues. If you have other printers on the Mac and use this reset, you will need to readd them later.)
2. Click ADD. Printer Browser window appears. At this point your Epson printer must be on and connected.
3. Highlight the desired Epson printer model and click the MORE PRINTERS button at the bottom of the window. (Do not change any other fields.)
4. A window now opens which is identical to 10.2. and 10.3, where you can select EPSON USB (not plain "USB") or EPSON FIREWIRE (if using the firewire connection) at the top of the screen. Highlight your printer's name when it appears below and hit ADD to return to the Printer List.
5. If you have other printers on the same Mac, ensure the Epson is the default printer. Close Printer Setup Utility.
6. You are now ready to print. When setting up a print job in any program, ensure that under File > Page Setup and File > Print you have selected your printer's name (rather than "Any printer") in the "Printer" and/or "Format for" fields.
pls rate as fixya if it helps and reply if issue persist, thanks!!!
Posted on May 20, 2008
  • Marcy Brennan May 22, 2014
    I don't have anything relating to Printing showing up in my Utilities folder. Using Mavericks 10.9.2
This was really helpful. Once I had moved the Epson folder to Trash and downloaded the driver from the link, my printer appeared in the set up utility in all 3 windows. I chickened out of deleting and resetting as everything that I could not get before was now all there. "Add" was no longer "greyed out" so I just went for it.... and hey presto it works!
Thanks Basti for leading me down this route. I've tried many many things including just downloading the drivers. I think it's trashing the Epson folder that made the difference.
Posted on Jan 09, 2009
Aswell as my daughter I've installed the drivers (Vista and 7) of the Lexmark x4550 wireless, but she can only print when my laptop is 'on'. How can she print without the use of my laptop.
All you need to do is to remove the printer currently added on your daughter's laptop(most likely it is the printer installed on your laptop)and then add the lexmark printer manually on your daughters laptop. Make sure when you do this your laptop is turned off. If this won't work, that means that the laptop of your daughter does not detect the wireless printer.
hope this helps...
Sep 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
I have a Pixma MP620 connected to Win7, but have wireless access and also use MacBook. Cannot print wirelessly to printer from Mac..........have a solution?
Make sure you have the drivers installed - while there are possibly compatible drivers that came with your MacBook, it may not work properly out of the box.
Download them from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp620#DriversAndSoftware. Make sure you choose "MP Drivers for Network". Do not install yet, but open the package file.
The next step requires a USB cable. You need to connect the MacBook to the printer and only then start to install the drivers by clicking the Setup icon.
You should do the 'Easy Install', if you get asked for it. When the installer asks to restart the machine, do so.
Once the machine restarts, you'll get a window for the 'Canon IJ Network Tool'. Click for 'Lan Connection', and then OK.
You'll want to click the 'Register Printer' button next. You may get a 'Cancel Setup' screen, just cancel that out.
The next part requires waiting. After a bit - really, it was different for all three computers, so I can't say how long - you'll get an 'Add Printer' screen. Choose 'Canon MP620 series', and click add.
On the Canon iJ Network Scanner Selector screen, set the pulldown for "Canon MP620 series Network', and then click the MAC Address (there should be only one) and cick 'Apply'. Make sure the check mark is displayed, then click exit.
That should register your laptop as allowed with your printer. Turn off the printer, disconnect the USB cable, turn the printer back on and you should be able to use it.
Apr 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
How do I get my Canon PIXMA 340 to print with my MAc running OSX 10.4.1? It works perfectly well with my other Mac running Snow Leopard. I thought I downloaded the drivers for 10.4 but when I try to...
Make sure that these is how the installation went through(provided that the installer is already downloaded to your computer:
  1. Double-click the file to mount the Disk Image.
  2. Double-click the mounted Disk Image.
  3. Double-click the .pkg file in the folder. Installation starts automatically.
Moving forward when adding a printer and the Ok button is grayed-out is that there are no other pop-out window or tick box that hasn't been ticked yet.
Jan 17, 2011 | Canon PIXMA MX340 Wireless Office...
Have 2001 quicken running on windows vista. when i try to print the check register, it says cannot open printer. i bought 2009 quicken and started to install, but it said it cannot save old register. it...
Dear Sir/Madam,
To resolve this issue:
  1. From the Quicken File menu, choose Printer Setup, and then select the form that you are trying to print.
  2. Make sure that all selections and settings in the Printer Setup window are correct, especially the selection in the Printer drop-down list.
  3. If all information is correct, click Cancel and proceed to step 4. Otherwise, click OK after making the necessary corrections, and then try printing again.
  4. If the message persists, exit Quicken.
  5. Click the Microsoft® Windows® Start button, choose Settings, and then choose Printers.
  6. Right-click your printer and choose Properties.
  7. Click the Advanced tab, clear the Enable advanced printing features checkbox, and then click OK. Restart Quicken and try printing again.
  8. If the message persists, exit Quicken.
  9. Double-click Add Printer and proceed through the Add Printer wizard until you reach the window that asks for the printer manufacturer and model.
  10. Select the manufacturer for ex. HP, and then select the printer HP DeskJet 550C (or any other HP DeskJet 500 series printer). Follow the onscreen directions in the wizard to finish adding the printer.
  11. Restart Quicken. From the File menu, choose Printer Setup, and then select the form that you are trying to print.
  12. Select the printer you added in step 10 from the Printer drop-down list and then click OK.
Completely uninstall the old version and install the new version. Before install clear registry and temp files. Update the latest driver for printer.
Thanks
Good Luck
Sep 24, 2009 | Microsoft Computers & Internet
Is it Mac compatible?
It is Mac Compatible.
Question: Did you install the correct driver for the correct OS? Sounds like you may have a compatibility issue in that respect. Remove it and try again is my best guess.
The link to the Mac driver page is here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&dlc=en&cc=us&lang=en&product=439486
Hope this helps :)
May 01, 2009 | HP Photosmart 3110 All-In-One InkJet...
Printer ok scanner not ok
If you have added through the add printer wizard you have added jus the printer software.....try to install through the software cd that came with it....
Please dont forget to vote
Cheers!
Nov 13, 2008 | HP Photosmart C3180 All-In-One InkJet...
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | Computers & Internet
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
HP OJ 7410 printer disappeared
Nothing to worry about. Go to HP.com and from there select Software and Driver Downloads. Download the Full feature software and driver for windows Vista. Run the Installation.
If the softwares are installed it will ask you to "Add a device". Add a device and select network option. The device will be installed. Now there is a patch on HP.com for unexpected uninstallation. Download it and install it on the computer. It will resolved the issue.
Feb 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Epson Stylus R265 InkJet Photo Printer Logo
5,028 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
