Question about H2O Audio Nissan Forklift Starter H20 H20ii H25 Eng Parts
My forklift nissan 25 not continous to run becouse of air in injection pump system
How to fix code p1421 on 2010 Nissan versa
Possible causes - Lack of intake air volume (blocked air filter)
- Fuel injection system (Clogged fuel injector or bad fuel pump)
- Faulty Engine Control Module (ECM)
- Reprogram ECM
Nov 10, 2016 | Nissan Cars & Trucks
How to replace air pump on a 2001 cadillac deville
P0410 Secondary Air injection System Troubleshooting ...
? 4:23
www.youtube.com/watch?v=dIrmkxj6wJE
Oct 3, 2008 - Uploaded by richpin06a P0410 Secondary Air injection System. ... I have a 2001 Saturn S-series showing this code. The air pump was not running. ... The fix for me was to replace the hose/wire that runs from the diverter valve, over a crevice on the ...
Sep 08, 2015 | 2001 Cadillac DeVille
What does obd 1 code 25 and 26 mean?
EOBD II Error Code: 25
Description:
System too Lean, Bank 1
Possible Causes:
- Intake/exhaust leak.
- Secondary air injection (AIR) system.
- Manifold absolute pressure (MAP) sensor.
- Mass air flow (MAF) sensor.
- Fuel pressure/pump.
- Injector(s).
- Evaporation emission (EVAP) canister purge valve.
- Heated oxygen sensor (HO2S).
- Contaminated fuel.
EOBD II Error Code: 26
Fault Location:
System too Rich, Bank 1
Description:
- Evaporation emission (EVAP) canister purge valve .
- Fuel pressure.
- Injector(s).
Hope that works.
May 24, 2014 | 1995 Toyota 4Runner
Failed smog due to "air injection"
What did you find wrong with the Thermactor/air injection system? If it was a system fault code that indicated the system is not working you likely need to replace the electric pump for the injection. Air injection speeds up the Catalytic chemical process by adding Oxygen when the engine is cold and Hydrocarbon production by the engine is higher. It runs for a very short time and then is shut down by the on board computer when it see the correct O2 signals.
Jul 06, 2012 | 2003 Nissan 350Z
HELP ME WITH THESE CODES!!
What engine ? 3.8 or 5.3 L
DTC P0128: Engine Coolant Temperature (ECT) Below Thermostat Regulations Temperature
DTC P0411 : Secondary Air Injection (AIR) System Incorrect Air Flow Detected
DTC P2440 : Secondary Air Injection (AIR) Valve Stuck Open
DTC P2431 : Secondary Air Injection (AIR) System Pressure Sensor Performance
Circuit/System Description
The secondary air injection (AIR) system aids in the reduction of hydrocarbon emissions during a cold start. The system forces fresh filtered air into the exhaust stream in order to accelerate the catalyst operation. An electric air pump, the secondary AIR injection pump, provides filtered air on demand to the AIR control solenoid valve/pressure sensor assembly. The AIR control solenoid valve/pressure sensor assembly controls the flow of air from the AIR pump to the exhaust manifold. The AIR solenoid valve relay supplies the current needed to operate the AIR solenoid valve/pressure sensor assembly. A pressure sensor is used to monitor the air flow from the AIR pump. The powertrain control module (PCM) supplies the internal pressure sensor with a 5-volt reference, an electrical ground, and a signal circuit.
The AIR diagnostic uses 3 phases to test the AIR system:
DTCs P0411 and P2430 run during Phase 1
DTCs P2430 and P2440 run during Phase 2
DTC P2444 runs during Phase 3
During phase 1, both the AIR pump and the solenoid valve are activated. Normal secondary air function occurs. Expected system pressure is 8-10 kPa above BARO.
During phase 2, only the AIR pump is activated. The solenoid valve is closed. Pressure sensor performance and solenoid valve deactivation are tested. Expected system pressure is 15-20 kPa above BARO.
During phase 3, neither the AIR pump nor the solenoid valve is activated. AIR pump deactivation is tested. Expected system pressure equals BARO.
In all 3 phases, testing is accomplished by comparing the measured pressure against the expected pressure. The PCM can detect faults in the AIR pump, AIR solenoid valve/pressure sensor assembly, and the exhaust check valve. The pressure sensor can also detect leaks and restrictions in the secondary AIR system plumbing.
Chevrolet Malibu P2432 Secondary Air Injection System
Jan 29, 2018 | 2006 Pontiac Grand Prix
Fuel filter is location under car? my car will die out if fuel pedal is pushed to hard. starts right back up but does not like to be excellerated fast.
check your air filter is not blocked.Try running it without the air filter fitted.if that does not solve the problem i would suggest a new air flow meter be fitted.
Dec 30, 2010 | 1991 Buick Century
I fixed used injection pump to engine and is not starting,i check oniy to fine out that the pump is not injecting fuel to the injectors.the timing is good.it is nissan navara 2000 model
1) There could be an air lock to the fuel system, try to bleed the system.
2) If the fuel is reaching the injector pump & not supplying to the injectors nozzles thn the pump needs attention.
Hope this helps!
Aug 18, 2010 | 1997 Nissan Pickup
Secondary air injection system malfunction
CHECK AIR PUMP FUSE 25 AMP AND CHECK THE SECONDARY AIR INJECTION PUMP RELAY.IF ALL IS GOOD AIR PUMP HAS A BAD SOLENOID OR THE PUMP IS FAULTY.
Mar 01, 2010 | 2004 Chevrolet TrailBlazer
My 1998 atlas copco xas 97 185cfm deutch diesel shuts down when i open full air
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
Nov 04, 2009 | Air Tools & Compressors
H2O Audio Nissan Forklift Starter H20 H20ii  H25 Eng Parts Logo
113 people viewed this question
Top H2O Audio Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a H2O Audio Toy Expert? Answer questions, earn points and help others
