When I switch the laptop on I get the following message and 2 beeps:'no bootable device(s) selected' 'strike F1 to retry boot F2 for set-up utility' i then retry the boot but get the same message appearing on screen.
    Problem Solver:
  • 10 Answers
I'm not an expert, but try getting into the BIOS when booting up (sounds like F2 on yours) and look for where you can specify the BOOT ORDER. It is usually First Device - Floppy, Second Device - HDD (Hard Disk Drive) and maybe no third device if not CD-ROM, etc. My desktop is currently CD-ROM first and HDD second. As long as I don't leave a cd or dvd in a drive, no worries. I am not even sure that a music cd or a movie dvd would hurt anything - it might skip the CD-ROM at theat point and still boot from the HDD as it should. Thinking some more, your BIOS might be corrupted and need to be reflashed if possible; or maybe your CMOS battery is weak or dead. Looks like a watch "coin" type battery on the motherboard (at least in a desktop pc).
Posted on Jul 13, 2010
No bootable device detected
If you strike F1, the system retries as said in the comment. That does'nt solve anything. Rather strike F2 which allows to enter the setup menus of your computer.
In this area you should understand what you are doing. Any update of setupdata may prevent further restart. At least take note of values and changes. You exit setup via a question "update Y/N". Then the computer restarts.
Anyway, in the setup menu you may inspect the devices and see if you the system identifies the disk. If not it may come from a bad connection of hard disk (sata pins, ...) or from low level disk information (format information).
With setup menu you may get in the boot order menu, that allows for the selection of an alternate boot media. You may boot on an installation media, ( install DVD generally, like originall windows install DVD) in order to understand and repair the situation, or from a rescue system like UBCD. You may also try Ubuntu from the CD without installing, just to verify if you may see the disk in the configuration.
Regards
Jul 09, 2014 | HP Computers & Internet
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
No boot device available - strike F1 to retry boot, F2 for setup
again check is bios is there set first deviced as cd rom dvd rom?
If it is just clean your bootable windows cd with hand caurchief.
Then check if it not boot with disk then your cd disk of windows is not bootable or faulty.
Please let me know.
Jun 06, 2009 | Dell Dimension 8400 PC Desktop
Ispiron 4000 wont boot up
Your Hard Drive Needs to be Replaced
Jan 10, 2009 | Dell Inspiron 4000 Notebook
Ndevice available
Press F2 go into the BIOS, check the hard disk settings, make sure it is set to auto (detect)
Nov 08, 2008 | Dell Latitude C640 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Open Questions:
Acer Virus Removal ' Remove Acer Virus - DataAlign ' Call +1888784-9316 Since those early days of laptop production, Acer has grown to offer devices in just about every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. While many consumers consider products made by companies like Dell or Sony to be at the higher end of the laptop spectrum, savvy consumers are beginning to realize that although they are priced competitively, support acer laptops do not lag behind in quality at all. As the company continues to grow, there is speculation that they may also enter the tablet and smartphone markets as well. For the all-round support of Acer customers, we have trained a team of highly skilled, certified engineers with excellent knowledge for all issues particularly faced with Acer products. Technical support is provided 24/7 every day on our toll free helpline called acer computer support number. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues All these issues can be resolved by our round the clock available highly experienced tech support team with dedication and professional attitude, contact acer support. Our services: Get all your queries, issues and complaints sorted out most efficiently and in the least time with most effective results that stay for the longest duration by contacting our Acer Support team members by calling on acer customer service. Contact our technical support team for any assistance regarding issues concerning Acer Products by acer product support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 20, 2018 | Acer Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
