Question about Philips Magnavox 42MF521D/37 Television
42 philips plasma tv
42" philips plasma blue light is on but just clicks. tv sat for three months then i tried it again and it worked for 1 week. Last night i went to bed and shut the power on tv off and woke up this morning to tv clicking and blueclight was on
Take off the back panel, probably about 30 little screws, make sure to replace the allan key screws when transporting the tv, almost broke me and my wife's toes when we moved the tv and the stand slid out and fell just by our toes, amazed it did not smash. Then check out your capacitors, they are round and have 'X' or cross marks, if these are popped out by any amount, and have some kind of dark stuff oozing out, then they need to be replaced. You will need a soldering gun/iron, solder, and replacement capacitors, i had to do 5, in two different sizes or voltage, took me about 3 hours in total not mentioning the driving around i did first looking for the capacitors, but was worth it, tv works fine now and cost me about $20 for capacitors and solder.
Posted on Mar 24, 2012
My tv wont turn on makes clicking noise and there is a green light in the back flickering
Posted on Jul 19, 2010
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Jan 25, 2010 | Philips Televison & Video
Blinking red led light when I plug in the tv then it turns right
Phillips purchases the main circuit board from Samsung, and it has a problem with capacitors failing. The failed capacitors can be easily identified as the top will no longer be flat, but will have bulged up.
If you have a local TV repair shop they can help you.
Jul 26, 2009 | Philips 42PF7220A 42 in. Plasma Television
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Phillips 42" plasma42pf5321d-35
Replace the small signal board 313926727671.
Oct 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42" plasma model pf5521d
The Z sustain module blew it's transistors. It may have been initiated by the Y sustain board going bad. I always replace both at the same time so as not to waste $250. You will find a Y sus board will run you between $250 to $350 and a Z sus is a little cheaper. I wouldn't replace one without the other. Let me know if this helps.
Sep 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips magnavox plasma tv model 42mf7010/17
Turn off the video mute if it has this setting. Try using a VCR tuner and connect the VCR to the TV on AV1 or AV2 inputs. THis fix is free until Feb. 09. After that, you will need a DTV converter box or pay for a cable/sat box.
Jul 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
42fd9954
Not a fix, but it got my tv on.
I removed the back and tried the power switch.
I located the relay that was clicking.
I have two blue relays in the middle of my power board.
I placed a hair dryer over the relay for a few minutes.
After four tries of the power switch and it stays on!!!!!
Heat keeps the relay from just clicking off.
I don't know why.
This will at least get the tv on though.
Oct 16, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips Magnavox 42MF521D/37 Television Logo
518 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
