Question about Epson Office Equipment & Supplies
Epson Stylus T21 printer not accepting ink supply system
I have bought an Epson Stylus T21 printer with continous Ink Supply system but since I filled the ink an installed the CISS catridge the red light is always on I have tried many troubleshooting tech..s including removing air from the ink pipes using syringe, please advise me how to get the CISS recognised by the priter.
thanks
Eddie Mog
  • 5 Answers
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Posted on Aug 26, 2010
Does not print, just a faint black print, the cartriges are half full.
your printer is a photo printer which consumes considerable amount of inks when printing... you may need to perform a head cleaning process to clear the clogg on your nozzle. this may consume your ink cartridges... i suggest that you convert your printer into a CISS (continous ink supply system) this is more cost effective instead of buying ink per ink as this shows the same output as the regular ones.
check out ebay for people who convert epson system to CISS
note: doing the head cleaning process always takes ink to force the clogg out of the nozzle tube
hope this helps
Aug 07, 2011 | Epson Stylus R265 InkJet Photo Printer
How to convert epson stylus nx125 to continous ink?
There a several continuous ink supply systems (CISS) on the market.
I suggest you Google search for these ink systems for your printer and you will get a price comparison from the various suppliers.
Jun 23, 2011 | Epson Office Equipment & Supplies
The black ink will npt come through
If you have just installed a new ink cartridge and an ink low or Replace ink cartridge message is still displayed, the cartridge may be incorrectly installed.
Follow these steps to make sure the cartridges are correctly installed:
  1. Press the On button to turn on the Epson Stylus, or (if already on) press the Setup button.
  2. Select Maintenance and press OK.
  3. Select Change Ink Cartridge and press OK.
  4. Open the scanner.
  5. Open the cartridge cover.
  6. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  7. Close the ink cartridge cover and push it down until it clicks into place.
  8. Close the scanner.
  9. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while ink is charging or you'll waste ink.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 16, 2010 | Epson Stylus NX400 InkJet Printer
Where do I find ink supply level on epson 2200 ink
Open the Epson Printer Utility, Click on the printer name if you have more than one printer then OK. Click on Epson Status Monitor at top. A dialog box will come up telling you if any ink needs to be replaced. Click on the OK button in this box and this will take you to another dialog box which will show you the amount of ink left for each color.
Mar 22, 2010 | Epson Stylus 2200 InkJet Photo Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Refill system for used Epson Stylus C67 cartridges
Hi Edulfo - my advice is to buy compatible cartridges. These are not refills but new cartridges that will work in your printer, but are not made by Epson. See your local e-bay site for very low cost cartridges of this type.
In addition, there are "Continuous Ink Supply Systems" (CISS) which replace the cartridges with bottles of ink. See:
http://cgi.ebay.co.uk/CISS-FOR-EPSON-C67-C87-CX3700-CONTINUOUS-INK-SYSTEM-_W0QQitemZ220307456327QQcmdZViewItem
for information about these. Once again e-bay is the cheapest source.
Mar 21, 2009 | Epson Stylus C86 InkJet Printer
New ink caretridges not getting accepted by epson stylus cx4400
Try removing the cartridges and cleaning the metal contacts with alcohol where the carts sit
Mar 03, 2009 | Epson Stylus CX4400 All-In-One InkJet...
EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
351 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
