Question about Garden
Subject: Changing Light Bulbs in Track Lights on a 20 foot high vaulted ceiling We have a contemporary house with a 20 foot vaulted ceiling. It has a track light at the tallest area of the ceiling. The problem is changing the light bulbs. Several of them can be changed using the long pole with a  device on the end designed to aid in removing and installing a light bulb.  However others have a grill which must be removed and replaced when light bulbs are changed. My first thought was to purchase an 18 foot "A" free standing ladder. TMhey are not easy to find and are very expensive. Any suggestions? Many thanks! Robert Wood
  • 2,100 Answers
We have the same problem at out church, the ceiling is 25' at the Peak! Most of the lights are below that, but we have to set scaffolding to change them, and to work on the projectors. It wouldn't be bad if it was just a bulb but it is those halogen bulbs that you can't touch with your skin, we also have an 18 foot fiberglass step ladder to reach some of the lower ones. It is a fairly light ladder, comes in real handy. If you put your bulbs in loose, they come out easier, with your pole there, but some are just impossible to get out. Don't buy one of those metal folding mouse trap ladders, they weigh a ton. They extend, but the take 3 gorilla's to get them positioned. I think we got out ladder from a home depot. Hope this helps.
Posted on Jul 11, 2010
  • Robert H Wood Jul 11, 2010
    When I install a new screw-in bulb I put a very light coat of silicone grease on the threads of the new bulb before installation. This prevents corrosion of the threads and makes a lot easier to remove a burned out bulb. You can purchase the silicone grease at Home Depot or Lowes in their plumbing department. A little container of it costs about $3.
The back of my Turn of the Century fan's remote control has this switch in the back of the battery housing. It's marked with 'D' and 'CFL' on either end. Can someone tell me what this switch means?
The switch is allows you to tell the remote which type of light bulb you have installed in the fixture. The CFL setting is for the included compact fluorescent bulbs. With these bulbs, you can only turn them on and off. If you put in incandescent bulbs, set the remote to D. Then you can dim the lights in the ceiling fan, in addition to turning them on and off with the remote. CFL bulbs can't be dimmed with this fixture.
I found this described in the manual for the Turn of the Century Midori 52" ceiling fan. This fan is available at Menards: https://www.menards.com/main/lighting-ceiling-fans/ceiling-fans/indoor-ceiling-fans/turn-of-the-century-reg-midori-52-contemporary-ceiling-fan/20338/p-1444433460319.htm . The direct link to the manual is currently https://hw.menardc.com/main/items/media/HONGK003/Install_Instruct/3551058-3551059_install.pdf .
I hope this helps.
Apr 01, 2018 | Dryers
Tip
Attic Insulation and Energy Costs
This short Testimonial is meant to help you save money on your energy costs as I tell you the horror story that I recently went through..
My brother in law recently bought a 2900 square foot house with huge vaulted ceilings and a large Atrium. We started doing rennovations to the house and Mike comes to me and asks me to check out his 2 furnaces. I asked him why, and he explained to me that the 1st 13 days of work we had done cost him $270.00 to heat the house and when he contacted our local gas company, they told him that the winter months cost the previous owners over $600.00/ month. Mike was ready to sell the house. I checked out the furnaces and they were functioning fine. I decided to go into the attic and look to see how much insulation was in the ceiling. What I saw next is something I have never seen in my 20 plus years building houses. There was zero insulation up there. It took many days to roll and blow insulation in the ceiling but first full months gas bill was under $400.00. His case was extreme but it cut a third of his energy costs. Insulation is something that you can do to your home that will start saving you money from the day you put it in, no matter what the season. I also recommend that people install humidifiers into their heating systems and keep them set at 40-45. By adding humidity to the home, you can keep the thermostat turned down and be just as comfortable while saving @ 5% of your energy costs for the month. Good Luck and save that hard earned money.
on Jan 19, 2010 | Heating & Cooling
Why will the lights no longer come on, on my ceiling fan, when the fan works fine & everything else is fine? What happened?
you get a slight shock suggests that you have a major wiring problem
at some point the installing electrician has used a ground wire as a neutral wire and there is live feed back that should not be occurring
Get in an accredited professional electrical inspector to run a full scan and test on the house wiring and then go from there
Jan 01, 2018 | Home
The fan operates correctly, but I cannot get the lights to work. There are 4 candelabra bulbs. The bulb receptacles have 110 VAC on them. Once bulbs are installed, the voltage to bulbs drop out.
There are two ways that ceiling fans are wired.
1. you turn on the wall switch and then you have one pull for the light (on and off), one pull for direction (clockwise, anti-clockwise) and one pull for three speeds and off.
2. you turn the wall switch on and the light comes on. There are two pull switches one pull for direction and one pull for three speeds and off.
Check your wiring from the installation instructions, the wiring in the ceiling.
Sep 29, 2015 | Dryers
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Our ceiling fan lights are blinking. There are 3 bulbs that have always worked fine until yesterday when they all 3 started blinking in unison.
sounds like you have a lose wire, pull the light housing and check the connections. If all is good, drop the unit, and check the connections in the ceiling. You have a short in the power , and is showing you when the fan is spinning. I would not use light or fan till fixed.
Mar 13, 2011 | Hunter (25417) Ceiling Fan
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
Track lighting remote control similar to that of ceiling fan?
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
Jun 03, 2010 | Universal Remote Control Hampton Bay...
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
Changing downlight globes
if its the gu10 bulbs that you twist round to release them well theres a small ****** that sticks on the bulb and removes it leaving the actual light fitting in the ceiling.
Sep 27, 2009 | Electrical Supplies
Garden Logo
15 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
