Question about D-Link (DDI604) Router
How do i succore my router
How do i keep people from using my wireless router
  • susanmason38 Jul 11, 2010
    i have the disk and it did not tell me anything i do not have the book
  • 43 Answers
You should setup as secure, so a "key" is required to connect. If you have the manual or setup/install disc it will help you set this up.
Posted on Jul 11, 2010
Samsung rv511 keeps loosing internet connection, internet turned on...
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Apr 12, 2013 | Samsung Rv511
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Jan 26, 2013 | Linksys WRT54G2 Wireless Router
I have a acer laptop the keeps turning off wirless connection
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 20, 2012 | Computers & Internet
Netgear dgn1000 modem router keeps dropping out
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 29, 2012 | NetGear Computers & Internet
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
How do i set the password for my wireless and i using the SMC router now. Pls help, people are keep using my wireless and my internet keep disconnect .
Setting up a login password only protects your wireless router from someone changing your wireless settings.
To secure your wireless network from unauthotized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 21, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Have wireless G plus MIMO router and lapto using a
Please enter to the router page and decrese the chanel. make it to 6 or 11
May 01, 2010 | Belkin (F5D6230-3) Wireless Router
Is there anything in a PC that can cause interference with a wireless network? Because firefox ate my earlier question, I'll keep this short: PC used to keep laptop from connecting to internet when it was...
there is nothing inside a PC that will keep it or anything else from connecting to a wireless network. You have to lookout for things that use the same frequency such as cordless phones and believe it or not microwave ovens. both broadcast at 2.4Ghz which is the same frequency wireless routers and access points use. Your problem may also be a neighbor with a wireless router or access point using the same channel. Wireless routers and access points have 11 different channels that they can broadcast on and if you and your neighbor are using the same channel there will be interference. try changing the channel on your wireless router or access point.
Apr 14, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
Keep getting disconnected from xbox live, for 5 seconds, then back online !!! pls help
Is your X-box wireless and are you using a wireless router?
If you are using a wireless router and it is getting disconnected, then you will need to check the wireless settings of the router.
You can try to upgrade the Firmware of the router. or change the advanced wireless settings of the router.
On your wireless router you will find the advanced wireless settings.
You will need to change BEACON Interval to 75.
RTS threshold to 2307.
Fragmentation threshold to 2306.
if possible then reduce the MTU on the router to 1365.
For more info about networking Click Here
Oct 06, 2009 | Computers & Internet
D-Link (DDI604) Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
