Question about Robotoolz RT-7210-1G Self-Leveling, Remote-Controlled Green Beam Laser Leve
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed around or dropped. I need a manual or some guidanbce as to repair. Thanks in advance
    New Friend:
  • 3 Answers
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Posted on Oct 02, 2013
3 Suggested Answers
  • 165 Answers
SOURCE: I have an robotoolz rt-7690-2 unit will come on
I don't believe that the unit has a spinning laser. Mirrors are used to split the beam into several beams that indicate plumb, level and righ angles
Posted on Mar 01, 2010
#1 Taper
  • 1041 Answers
SOURCE: I sent my unit in
There seems to be much confusion with the leveling feature of this tool. The directions are not real clear either whenit comes to leveling. You should call the manufacturer to get tech support. I will send you a link to there site and phone #.
http://www.toolauthority.com/RoboToolz-RT-5250-2XPK.html
Good Luck!
Jim
Posted on Sep 16, 2010
Robotoolz Laser RB01001 calibration and manual
http://www.microprecision.com/instrument/ROBOTOOLZ-RB01001%20-CALIBRATION.html This would be a professional calibration to many known standards. I hope this helps you out. Thanks for visiting and leave feedback! I'm a newbie
Jul 10, 2016 | Robotoolz Measuring Tools & Sensors
I own a RT-3620-2. The liquid in one of the leveling windows has leeked out. Can I get this repaired?
Contact a laser service center. I doubt anyone will be willing to work on it. It would be a lot of research for a 2.00 part. Usually you will be unable to find parts for big box store lasers. A laser dealer may have a broken one laying around that he can pull a used part from. Just a a precaution I'd recommend never purchasing a laser from a retail store such a sears or home depot. If possible go with a Leica Geo-systems unit. Topcon, spectra physics, and trimble are also good lasers that have all parts readily available. In the service industry we call cst, bosch, robotoolz, "throw away lasers" because if anything at all goes wrong you throw it away. If i recall properly I have searched for parts for Robotoolz and contacted the manufacturer in the past. I was told that they are not supported and parts are not available. Check around and see if you can find a service center with a used part. Google search (Leica Geosystems, Topcon, Trimble Laser dealer).
Jun 01, 2014 | Robotoolz RT-3620-2K mPlane Level, Plumb &...
Laser level problem
I had the same issue. The laser would only turn on intermittently and mostly not turn on at all. Since the green led would come on for 2 seconds when you first turn the rotary laser unit on (as per the user manual) I decided that the problem was probably with the remote. I took it apart (4 screws) and cleaned the corrosion off of the battery contacts on the slider switch and the two plates that the switch sliders make contact with. I also bent the two thin slider contacts so that they would contact the corresponding plates on the circuit board with a little more pressure. Put it back together and that seemed to fix it.
Feb 19, 2014 | Robotoolz RT-7210-1G Robolaser,...
Robolaser rb01001
The lock lever must be stuck. Check the locking lever.
Jan 21, 2014 | Measuring Tools & Sensors
The laser will not light up. i've replaced the batteries
First, be sure to clean the battery connection points with an electrical contact cleaner and be sure that the batteries are new, not just different. If that does not work, try placing the instrument in a freezer for at least 30 minutes. This worked with my 5 point Stanley Fat Max. The freezer will cause some condensation to form on the inside of the instrument, but why it makes the diode work is a mystery, at least to me.
Sep 13, 2011 | Robotoolz RT-7210-1G Robolaser,...
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
Green light turns on momentarily, then nothing from unit
make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
May 28, 2010 | Robotoolz SelfLeveling Laser Level with...
Robotoolz RT-7210-1G Self-Leveling, Remote-Controlled Green Beam Laser Leve Logo
517 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
