Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Do I have to use ethanol free gasoline?
The gas stations that sell ethanol free gas are closing here in Vermont. I just purchased a Huskvarna 435 (16 inch bar). Will it run well on gasolinw tih 10% ethanol?
    Brigadier General:
  • 4,088 Answers
It had better do so--or any saw brand that fails to run on ethanol blended fuels will see sales fall rapidly in the USA. We, personally, own one of these same saws which (when new) ran great for about 3 days, then refused to start. A trip to the warranty repair station got us a new ignition module. After return, it ran for about two days, then would not start again. The warranty repair then installed a replacement carburetor and about a year later, still seems to be working fine--it's a great hard working saw when it operates correctly. Good luck!
Posted on Jul 11, 2010
Can Gas additives mess up your carb on a 2006 Road Star?
Yes,, and no.. depending on what you put in it... you DO NOT need additives for a motorcycles... USE a GOOD QUALITY Gasoline!!!
Drain the tanks and the carbs...
Put in fresh QUALITY NON-ETHANOL gas!!
Welcome to the definitive list of stations that sell pure ethanol free...
Jun 26, 2017 | 2006 Yamaha Road Star
What gas stations sell ethanol free fuel in the Macon GA. area?
Sorry we do not have that info. Suggest you call around to a new car dealer.
Apr 13, 2016 | Cars & Trucks
Is new gasoline "E" coming to gas stations?
The Ethanol in the fuel destroys neoprene rubber in fuel pumps and fuel lines, it also burns at a very high temperature causing valve damage in aluminium engines.. Harley Davidson do not recommend more than 20% Ethanol in fuel to avoid damage.
Oct 11, 2014 | Cars & Trucks
I have a Brigg Stratton Model # 10H902-0121-E1 engine. The dealer claims that because we use gasoline that contains ethanol, the carburetor screen/diaphragm gets clogged and will not run until those are...
I work on Briggs engines every day and I say that's a bunch of Hooey! I don't know of anyone who sells gasoline that is not 10 percent ethanol anymore and I do not have issues with it. If you are leaving your machine set for any period of time though, I do not recommend letting gas sit in the carburetor. And there is a very simple way to do this, as I do with all my machines. Go to the hardware store and get a gas shutoff valve (petcock) and install it in the gas line between where it comes out of the tank and where it goes into the carburetor. You'll have to buy a couple of clamps, as well (the valve is about $5 USD and the clamps are about 50 cents each). Then, when you are finished (or very close to finished) mowing, simply shut the petcock off and allow the mower to "Run out of gas". You're really just running the carburetor dry. Don't forget to turn it back on the next time you mow, or you'll be kicking yourself; trust me. Good luck to you.
Jun 30, 2011 | Craftsman Garden
2001 honda shadow what kind if fuel should i use
Regular unleaded should work well in your motorcycle; it may actually start and run better with regular than with premium gasoline.
The big wild card, however, is the amount of ethanol in the gas you are buying. Your bike would definitely run best on "pure" gasoline that contains little or no ethanol, but that's getting harder and harder to find. Personally, I have noticed that my bikes have started harder and run worse as the ethanol content in gasoline has increased. That's one reason I actually recommend staying away from premium, which sometimes has more ethanol in it than regular (it raises octane). I prefer to keep my bikes stock, rather than messing with the carb jets to compensate for the different performance curve of ethanol-blend gas.
If it's available in your area, you might try running your bike with some Cam2 racing gasoline to see if that makes a difference. You don't need the extra octane in that fuel, and some varieties of that fuel may still contain lead (a no-no for your engine), but it doesn't contain ethanol, as far as I know. Double-check with whoever is selling this fuel in your area to make sure you're getting the unleaded stuff. If you find that your bike runs well with this fuel, you might consider blending a bit of it with pump gas on going-forward basis.
May 31, 2011 | Honda RC 51 Motorcycles
S&s carby running very lean why?
If this is a new installation, your carb may not be jetted correctly or if the carb has been running for a while, you may have a vacuum leak somewhere. Your carb should be jetted 29.5-31 on the slow jet and 72-74 on the main with your 88" engine. If you've modified the exhaust, the jetting could varry a bit from that.
If your carb has been running for a while with no problems and you haven't changed anything and it's suddenly started running lean, I'd remove the carb and go through it. Check all the jets to make sure they aren't partially blocked. Check or replace the intake manifold gaskets where they join the heads. The carb has a vacuum takeoff point as well. It should have a hose supplying vacuum to your VOES and the vacuum operated petcock unless these items have been removed or replaced. Make sure that hose is in good condition.
Also, when you pull into a gas station, look on the pump and see what percentage of ethanol has been added to the fuel. Although I haven't seen it and cannot verify it, I've heard talk of some stations selling fuel that has more than 10% ethanol blended in with the gasoline. Since ethanol is basically alcohol, it will run leaner than gasoline with the same jets.
Good Luck
Steve
Nov 06, 2010 | 2000 Harley Davidson FLSTC Heritage...
I have a 2007 Lamborghini Gallardo Spyder. In the manual it recommends using pure gasoline and not an ethanol mix. However, all gas stations around OC and LA contain up to 10% ethanol. Could this damage...
that's not going to be enough to really hurt anything just use the high octane gas when you put gas in and you can also check with an exotic car service center to see if they would recommend a fuel conditioner or additive
Feb 28, 2010 | 2007 Lamborghini Gallardo Spyder...
When gets hot won't run has this happen to you?
The first thing I would check is the gasoline. If the gasoline is boiling these air bubbles will not allow the carburetor to regulate the gas properly. If you can get it, try some Amoco 93 octane white gas. In most areas this is now available at BP stations. If you can not get this in your area ask around to find a station selling gas which does not contain ethanol or alcohol. If you can not find that, then just change brands of gasoline and hope that you come up with one with a lower boiling point.
Sep 20, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
342 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
