Question about Whirlpool Heating & Cooling
Condensation coming into the house is my issue. Is there a relief valve on the bottom of the unit that can drain the water?
  • Whirlpool Master
  • 43,501 Answers
You need to have the unit tipped towards the outside or the water will run inside...lift the inside of the unit up and blockit up so that the water runs to the outside...
heatman101
Posted on Jul 12, 2010
Vulcan electric hot water heater. I want to know how to drain enough water out in order to replace the relief valve
turn off unit turn off water supply open drain at bottom let water out close drain remove valve
Aug 31, 2017 | Water Water Heaters
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
Rust in water heater tank
the tank needs flushed out ! heres how. Water heater manufacturers recommend flushing sediment from your storage type water heater periodically.
If your water heater is gas, set the gas valve to "Pilot" to prevent the burners from coming on while you are flushing it. If your heater is electric be sure to turn off the circuit breakers. With an electric water heater, if the water level drops below the heating elements and the thermostat turns the elements on, the heating elements will probably burn out quite rapidly. Connect a garden hose to the drain valve at the bottom of the tank, Close the shut off valve on the cold inlet to the water heater. open the temperature/pressure relief valve at the top of the tank by lifting the lever. Leave the valve open. Open the drain valve at the bottom of the heater allowing the water to flow out through the garden hose. when the water is clear your finished. close pressure relief valve on top of tank and turn water back on.
Open a hot water faucet in your house, and let it run until no air bubbles come out.
Turn the heater back on, and with gas units re-light the pilot light if necessary. good-day !
Apr 24, 2012 | Water Heaters
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
My water heater runs constantly lately and i noticed water at my property line and around half my house. i can't tell where the leak is coming from. house is on slab. i am afraid to ask. the floor...
Does the hot-water line running from the heater go into / under the slab before going back into the house?
Or does the pressure relief valve drain line on the water heater go into / under the slab ?
It could be as simple as a faulty pressure relief valve on the heater (which would be the most likely of the two possibilities). When the water heats, the pressure builds in the tank, the water flows out the faulty pressure relief valve and down the drain line under the slab.
A plumber would be the person to call.
Charlie
Feb 19, 2011 | Kitchen Ranges
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Hot water leaking from what i think to be the pop off valve. i tried to tighten it a little and it started leaking more. The unit is 16 years old. The excess water is draining into the catch pan and then...
    Hello
    16 yrs old? Im guesing this is a hot water heater.Not a air conditioner.
    If its still making hot water you may not need to replace the whole unit.
    The valve that is leaking is a high pressur relief valve and they do go bad the sprigs become weak over time and some corrosion may not allow the valve to seat properly.
    1st step is to shut off all incoming and out going water to the tank.
    2nd Shut off fuel or gas to the unit, and annonce to everyone your are working on the hot water heater.
    3rd at the very bottom should be a drain valve much like a hose spicket,open this slowly and drain the tank,remember the water will be hot.You may not need to drain it all the way,while draining pop open the relief valve,when you stop getting water from it,you are below it and can turn the drain valve off.
    4th remove old relief valve and replace with a new one,i think they are rated at 15 psi or 30 psi blowoff pressure,hopefully there is a tag on it with that info.
    When you go to install your new one use some pipe thread compound or teflon tape around the threads before you reinstall valve.
    Once done slowly refill tank with water, check for leaks.When full open up hot water valve to house and relight buner.open a faucet in kitchen to hot to bleed off any air.
    Jan 14, 2011 | Heating & Cooling
    Water heater overflowing
    Is it coming out the releif valve on the side or top. If so it can be replaced, just shut water,power and drain down and replace.It is a standard 3/4" thread and not to costly.
    Now it is the drain valve at the bottom turn everything off and drain it down and replace the drain valve.
    Check out these links below for pictures and details to help you with this issue.
    This link is for Pressure relief valve testing and replacement.
    http://www.water-heater-repair-guide.com/waterheaterreliefvalve.html
    The link below has an in depth details of how to change a drain valve out.
    http://www.water-heater-repair-guide.com/waterheaterdrainvalve.html
    Jun 24, 2010 | Water Heaters
    Flooded bathroom from top of unit
    The T&P valve (temperature and pressure) relief valve is suppose to have a 3/4 in drain line threaded into it .This line should have ran to a trapped drain or possibly to the outside of the house. A water heater cannot over fill. To drain your water heater run a garden hose to the outside or to the lowest drain you have nearby.If its still wet be carfull not to get shocked,Attach the garden hose to the drain valve located towards the bottom of the water heater. turn the valve on. If water dosnt come out of the other end of the hose,youll have to see if you can run a peice of wire through the valve into the water heater to get it to drain. This can somtimes be a real problem . I usually leave the water on when i first connect the hose to the drain valve. This allows the water pressure to flush the sedament out of the bottom of the water heater.
    Dec 04, 2009 | Water Heaters
    Heating & Cooling Logo
    32 people viewed this question
    Top Whirlpool Heating & Cooling Experts
    Bill Long
    Dennis Boxerman
    Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
