Question about Life Fitness 9100 Next Generation Remanufactured Treadmill
A strange noise from the motor begins to happen when I push the speed from 1.9 to 2.0
  • 79 Answers
Watch could be the bearings you should look for a technician, to open the drive motor and then change bearings
Posted on Sep 07, 2010
Testimonial: "Thank you. I had already had a technician examine my treadmill after I had contacted you. He examined the motor and said the nothing could be done. "
Kitchenaid mixer motor noise at lowest speed
Hi,have you set you speed of your rotations,maybe it's set to slow.you have to Adjust the screws in the backof the mixer,so the rotation of the motor is a second apart on the speed setting three.i quite sure that's the right speed number,I have it written down somewhere,if I can find it and it's different il let you know.ty hopethatworks.
May 16, 2014 | KitchenAid K5SS Heavy Duty Commercial...
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
Aug 20, 2011 | Samsung HLN5065W 50" Rear Projection...
This Fisher & Paykel GWL15 washer began making strange noises this week. When the water is pumping out, a loud, moaning or grinding sound is made. It also makes the sound after a few minutes at the...
Same thing happened to mine. There's a really simple solution: Lay the unit on it's back or lean it far enough back to have access. The pump is near the front and has a black fan blade on the bottom. Remove the electrical plug on the motor; it just pulls right off. Now look for a white plastic retaining lever near the top of the pump. Hold it out and turn the pump about 1/8 turn counter-clockwise, then it almost falls out. I found a safety pin inside that was causing my noise. Went back together just as easily. Problem solved!!!
Oct 13, 2010 | Fisher Paykel EcoSmart GWL15
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Strange loud buzzing noise on 1997 Ford Explorer XLT
Only thing that comes to mind with description is maybe heat shield on exhaust, getting loose. Wait until vehicle is cooled off and get under there & check any heat shields you see wrapped around or near exhaust, above it attached to floor of vehicle etc, and give them all a little shake or rap with rubber hammer or similar to see if any rattles are present.
Aug 24, 2009 | Ford Expedition EL Cars & Trucks
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Fan speed switch only works on #5
Call your local GMC Dealer and see if they have the climate control panel in stock. What happens is the circuit board on the back of the panel shorts out. The panel comes as an assembly and is very easy to replace. Don't go with a wrecking yard piece. I made that mistake once and it didn't work either. I got one from the Chevy dealer and it worked perfectly.
Aug 21, 2008 | 2002 GMC Sierra
Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
234 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
