Question about Amana Heating & Cooling
I have an Amana AP148D, can I run it without an external drain hose? It says self evaporating, what does this mean?
    Novelist:
  • 117 Answers
Self evaporating simply means there is a drain pan with a heater device installed that will evaporate and condensate that drains from the unit into the pan.
You do not need the external drain pan unless the unit makes more water than the drain pan and drain pan heater can handle.
Posted on Jul 11, 2010
Why is carpet damp or wet?
Sounds like the air conditioning evaporator/heater box has a blocked drain, when using a/c condensation will form on the evaporator, and should drain via hose externally...
The drain hose will run through the floor directly under where the a/c fan/evaporator box is located, you may have to remove some kick panels or part of dashboard to access the evaporator box to clean the drain hose....
Feb 13, 2016 | Cars & Trucks
I have a protable AC #AP148D from Amana I want to empty the water from the pan. where is the pan locate and how can i get to it
The pans are usually at the bottom of the unit. It may be a plug not a pan you remove to drain it.
Aug 02, 2011 | Amana Portable Air Conditioner
I have the amana ap148d and so far today i have had to drain it 3 times this is rediculous. it is not on the dehumidify mode so what is the problem
Dehumidifing is a produce of air conditioning, I would be thinking of a way to drain the tank with a drain hose so it will run continues. The water should slow down if your house is tight, but will still be contunue to make condensate.
Jul 08, 2011 | Heating & Cooling
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Mar 02, 2010 | Heating & Cooling
Do i have to drain out the water is this not a self evaporating unit ?
You have to connect the drain hose to any outdoor location . If it is a plate type condensor it is self evaporating. Or if the drain pan is on top of the compressor then you have to drain it out now and then.
Aug 15, 2009 | Amana Portable Air Conditioner
The only thing I need is a online manual instructions for amana ap148d so I can print.
Don't bother. Couldn't find it either. If you have a Stop error try draining the water from the pan. its not sealed so be careful if you pick it up. I had that problem Amana was NO help. Started right back up!
Jul 27, 2009 | Amana Portable Air Conditioner
I hav a amana ap148d and it shut off and the screen displays stop and wont turn bak on
Empty the water pan. It not sealed so dont slosh it around. Mine did the same thing. Amana rep was an ***. Wouldn't give me an inkling of what to do. So i started to fiddle around. There was a lot of water in it Be careful. I brought mine to the tub and drained it for close to 2 min. Started right back up!
Jul 18, 2009 | Amana Heating & Cooling
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
Bought Amana 7000 BTU portable air conditioner for my father and he is telling me that it's leaking all over. I thought it was a self absorbtion.
Self absorbtion means that the water is evaporated by the blower blowing air over the condensation. On very humid days there may be too much water to evaporate. There should be a drain outlet on the back and it may be blocked. Clean it if you can find it.
Jul 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
418 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
