Question about DBX Driverack-Pa Eq/Speaker Control System System
I have a dbx DriveRack PX Powered Speaker Optimizer. Occasionally, the volume drops significantly and at times drops out completely. Any suggestions on what that could be?
5 Suggested Answers
  • 518 Answers
SOURCE: DBX Driverack PX "Wizard" not allowing MONO
set it up as mono=common leads together and l,r,leads together,it will see left and right are in use and should load up
Posted on Jul 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: When I plug in my
Try reversing the polarity (orientation) of one AC power plug at a time.
Posted on Jan 23, 2011
c1apton15
  • 3400 Answers
SOURCE: Good day..The common problem in
The DBX driveracks work well with about any PA. The only PAs you might encounter a problem with would be one of the newer line array and digital processing PAs. Let your audio person get creative, the presets for multiple PAs are just a guide. If your sound person is confident and is qualified, let him/her experiment and/or rehearse - you'll be amazed at what that system is capable of.
Posted on Mar 10, 2011
dunnbiker
  • 8546 Answers
SOURCE: Getting ready to setup dbx driverack pa, with one
Apparently you can assign stuff like that. Get the manual.
ftp://ftp.dbxpro.com/pub/PDFs/discontinued/manuals/Studio%20DriveRack%20Manual.pdf
Lots of stuff here:
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/
Posted on Jul 29, 2011
I need maual to adjust it
im pretty sure you can download that information here at http://www.dbxpro.com/Literature.php.
Sep 04, 2011 | DBX Driverack PX EQ Speaker Management...
Good day..The common problem in a closed pa system setup is feedback.It limits the capacity of unit to give a higher intensity of volume..With this I just want to ask if DBX Driverack pa+ will work well...
Mar 10, 2011 | DBX Driverack-Pa Eq/Speaker Control System...
Jul 05, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
White screen on the dbx driverack pa? how to fix?
You can adjust the LCD contrast by pressing the Utility button and turning the dial one way or the other. Pressing the Utility button toggles back and forth between LCD contrast and Compressor/Limiter Threshold Meters, so since you can't see anything in the window you may have to press Utility twice, though I think LCD contrast is the first option.
Jan 17, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
When going through the driverack pa setup wizard, where is the "custom" speaker setting?
You should be able to spin the dial all the way to the end of the list of speakers and there you should see custom.
Jul 15, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
Signal to speakers periodically drops out
I can not tell for sure without seeing the unit; however, this often happens with stereo receivers when the contacts on the protection relay start to go bad. You can try to polish the contacts with emery cloth or a fiber brush but it is best to replace the relay if you can find one that will fit.
Jan 01, 2018 | DBX Driverack-Pa Eq/Speaker Control System...
We have a dbx Driverack PA unit with a Crown CDi1000 amp in our church. Recently, we starting having problems with the output to our main speakers dropping out. We found (by accident) that if we unplugged...
Check the speaker wires coming out of your amp. Chances are you have a problem with a speaker wire and this is just a coincidence. I say this because the same thing happened to me during a live show and I about had a heart attack. We lost the front of house for about 15 minutes while I tried to troubleshoot the Driverack, the board, and everything but the speakers and speaker wires. The cables were a recent purchase and were premium grade with light wear so I mistakenly ruled them out. It was intermittant so it took me a while to figure out. Now I understand that that's the weakest link in the chain and from now on I start there and work backward through the chain (that is, if all sound is cutting out).
Do you use banana plugs (two metal pegs sticking out of a plastic rectagle) coming out of the back of your amp? There are little screws inside the holes on the back of the banana plugs. Those can vibrate loose, especially if they're just factory tight. Get a little standard screwdriver and tighten them down. That will probably solve your problem.
Okay, wait a minute -- could be one more thing. You mention that the loud popping can be heard. Do you have any gates turned on? Most compressors have gates. Check your compressors to see if you have your gates turned up too high. A gate set too high would allow the loud pop to go through to the PA but would cut off everything low to mid-volume.
I guess you can see that I don't think it's a problem with the Driverack. I don't work for dbx or anything, I just think these other things are far more likely than a problem with the unit.
Jan 02, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
DBX Driverack-Pa Eq/Speaker Control System System Logo
99 people viewed this question
Top DBX Audio Players & Recorders Experts
Chickenwatt
Level 1 Expert
Vito Vacirca Jr.
Themcramers
Level 1 Expert
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
