Question about Weber Genesis Silver B Grill
Electric start does not work. Must be replaced.
Electric start does not work. Must be replaced. Now use manual lighter to start grill. However the grill does not light after turning gas on. Not surte if we need to replace burners? What should I check? next steps....
  • Frank Schultz
    Frank Schultz Jul 12, 2010
    Is it a push button igniter that clicks once per push, or a rotary that clicks once when you turn it? It could also be a button that you push that has a battery behind the button?
    Champion:
  • 274 Answers
Try replacing the hose and regulator, easy to do and inexpensive to start with.
Posted on Jul 12, 2010
Gas grill was washed now it won't light
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
Jul 13, 2012 | Grilling
Grill wont light
Hi there, can you let me know if it will light manually with matches,lighter or manual lighter. I'm trying to work out where the problem may be (gas or ignition). If you lift the gas tank is there liquid inside it.
May 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
My electric start button will not spark when pushing down, the grill is only one year old.
The issue might just be that the battery powering the starter is dead. There should be a small compartment where there is a small battery stored. Change out that battery as well as making sure all of the wires from the battery to the button to the lighter are all connected well.
Hope that helps!
May 11, 2011 | Weber Summit Silver B Grill
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
Not working nothing happens after depressnig the bellows like sectin of the scope
Hello, this is a piezo electric operator night vision monocular which is manufactured in Russia.
Piezo electric devise is the same thing one used to ignte the butane lighter when pulling the trigger. Or pushing the button on the gas grill.
You have to keep squeezing that bellow many time before thing start working, OK. Wish you lots of luck. GB...stewbison
Nov 10, 2010 | Famous Trails Ariel FT300 Monocular
Grill seems to flair up, doe not always light with 1st press of the ignitor(or 2nd, 3rd...) and then it does start and a gas filled burst of heat erupts
most grills do not lite on the first press of the igniter so this is a common situation, The best way to prevent this is make sure everything around the igniter is clean especially the burner. I've seen brand new grills do the for their entire service life so don't be discouraged if you can't correct the problem. Get a extended lighter and lite the grill manually, lite the lighter hold it next to the burner then turn the burner control on, Always lite a grill with the hood or cover open!!
May 21, 2010 | Frigidaire FD26NGDC (NG) Grill
Dynasty Gas Grill automatic lighter buttons not working
i dont know how old your grill is ut it most likely has batteries that need to be replaced
Aug 19, 2009 | Grilling
I HAVE A CHARMGLOW PROPANE GRILL
Yes you can. It's best to use a long lighter, You light the burner from under the grill. Should be air slots on bottom, keep lid up and do not turn burner on until ready with lighter. Sounds like you need a new piezoelectric ignition or a wire problem.
Thanks for using fixya
Jerry
Mar 29, 2009 | Brinkmann Grilling
Ignitor not working
I'm sure you have fixed yours by now, but if not, make sure the igniter wire is about 1/8" to 1/4" away from the fitting so it can produce a large enough spark to ignite it. Hope this helps!
May 14, 2007 | Kenmore 555 sq. in. Cooking Area Gas Grill...
Weber Genesis Silver B Grill Logo
296 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
