Question about Frigidaire FDL50R1 Dehumidifier
Drain hose is connected (tightly, have disconnected and reconnected several times) and bucket still fills with water. The unit is on a table and the hose drains into a sink that is below the table level. Any suggestions? THanks!
    Genius:
  • 1,417 Answers
what this indicate is that there is a blockage on the water pipe(drainage or hose)
what you will have to do to fix up the problem is to disconnect the hose from it position, than after you have disconnected the drain hose bale out the water if possible then you will see some dirty that have cost the water blockage from the hose flow remove any form of dirty you can fine around the hose then the water will be able to flow has expected
thank you and thanks for using fixya.
Posted on Jul 11, 2010
Why would the system keep running, all the time, filling up bucket, then leaking onto floor? What is my next step?
There is supposed to be an auto-shutoff float in the bucket to prevent overfilling of the bucket. You have either removed it or it is defective. The fact that it runs constantly has more to do with the humidity and the setting that you have the unit set to, Obviously there is adequate humidity in the space or the bucket would not fill. You need to look for, find, and repair the shut-off float, or, if possible, some units allow you to connect a drain hose either to the bucket or directly to the unit to drain the water to a drain. If you choose this option, remember that the hose must remain lower than the top of the bucket or it will not drain properly and the bucket will still overflow.
Jan 23, 2016 | Dehumidifiers
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
Hose is connected to dispose water but bucket fills up
First check that the opening from bucket to hose is clear of obstructions. If you used a washing machine hose and the filter screen is still in the end of the hose, then replace the screen with an ordinary hose gasket.
A gel-like growth can develop in the drain hose. Drain the bucket. Remove the hose and connect it to an outdoor faucet to flush the hose. Reconnect the hose using an ordinary hose gasket.
Oct 05, 2011 | Kenmore 54501 Dehumidifier
Do I have to do something, not mentioned in the manual to get my unit to drain out the hose connection. I know people are stupid, so yes I did open the connection and attached my hose. It has a bit of...
This is usually cased by either a clogged drain hose ro the hose connection and tubing on the unit is clogged. When this happens, water is diverted into the bucket.
First, turn the unit OFF & unplug it.
To unclog the connection and it's interior tubing. Disconnect the hose and using an 18" long plastic Zip Tie appropriately sized Zip Tie, carefully insert the tip into the hose connection and the tubing. Slowly push it in unitl you reach a bend in the tubing. You will need to gingerly work is past this bend, until the Zip Tip bottoms out or you run out of usable Zip Tie. Then slowly pull it out while rotation (twisting) it. This should breakup any clogs. As you reach the tip of the inserted Zip Tie, be prepared as some water may follow. Reconnect the hose to the connection, plug the unit back in, turn it On and lower the humidity extraction level to 35%. Monitor the hose periodically for water flow.
Be sure the hose slopes down and away from the unit and is not longer than 5 feet. As drainage relies entirely on gravity to drain.
NOTE: You may substitute something similar to a plastic Zip Tie. But, no wire coat hangers.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Frigidaire Dehumidifiers
Water fills in the bucket and will not drain
I've got the same problem. It drained through the hose for 6 months, but recently stopped and now fills the bucket. I connected a new hose, but that didn't help. I found some debris inside the dehumidifier (where you connect a hose to), but removing that didn't help. I may try taking the unit apart to see if somehow a cricket or some sludge got built up inside.
I'll post my findings. Hopefully it won't be too complex or nasty!!
Oct 06, 2010 | Frigidaire FDF50S Dehumidifier
I connected the hose adapter so that I can drain directly into the sink. But it still drains into the bucket. Did I miss a step?
I had the same problem. The plastic tube that routes the water out the back doesn't fit tightly. It took a couple of weeks but the bucket would fill and the darn thing would shut off.
My first attempt was to put a hose clamp over the adapter. The clamp was simple enough but then the bucket wouldn't go back in. Using a small saw, I carefully cut a notch in the bucket. WARNING: Make sure that whatever you cut doesn't reach low enough that when the bucket fills, the little float thingy shuts off the unit before it starts to leak. Anyway, that still leaked. The problem is that that plastic tube is stiff and slippery and doesn't seal well.
What finally worked for me was to take the adapter off, go to the hardware store and buy some clear plastic tubing. I found some that fit very tightly over the tube inside and, with the hose clamp, sealed well.
Problem solved.
Jul 03, 2010 | Maytag M7DH45B2A Dehumidifier
Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Oct 17, 2008 | LG LHD45EL Dehumidifier
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Frigidaire FDL50R1 Dehumidifier Logo
100 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
