Question about Refrigerators
We have a Frigidaire side by side with the in door ice and water system that utilizes the Pure Source 2 system. Dealer states that the filters whould last forever. After a short period, maybe 4 weeks or so, the water slows to a trickle. I replaced the valve assembly and this did not help I even put an older filter in and the flow was higher than the current unit. Also, check my inlet pressure which is fine. I'm guessing that if the water flow change with a filter change, that they do not last last long. Your comments...thanks for your help.
    Genius:
  • 1,073 Answers
No water filter on a ref will last forever, the company that built the filter would have filled chapter 7 11 or something
but the filter my or my not be the issue
what is the size of the ice cubes that it is making
are the normal size with no hollow centers
if you use the water in the door does it start out at regular stream and then decrease as long as you are getting water
you have replaced the water valve, i dont think it is bad, keep it as a spare
i wo uld go to the line valve that the ref is connected to the house plumbing and if it is a saddle valve, remove it and check for an obstruction at the saddle valve, and while it is removed bore ou the hole into the pipe it is clamped to to 1/8 of an inch with a drill bit and you should be ok
Posted on Apr 20, 2008
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Where do I find the filter that needs to be changed
Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Pure Source Water Filter inside the refrig. is overflowing
most likely you have a bad filter holder the part the filter connects to,next time send the model number off of the machine so whoever helps you can look up your model and send part numbers to you.
Dec 23, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replaced leaking filter but still leaking
Where is it leaking?, at the filter?, at the hook-ups on the filter?
Aug 22, 2009 | Frigidaire FRS23R4A Side by Side...
Water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
My parents frig had the same problem. The steel tabs that hold the filter in place are very small and frail. Heres what I did to solve the problem, at least temporarily. While firmly holding the filter release button, gently bend the tabs together using an extra long pair of curved needle nose pliers.
Apr 15, 2009 | Refrigerators
The water and ice tases and smells bad. New coil and filter.
Replace the water supply line with plastic tubing or copper. Do not use the braided metal or vinyl line as they will cause an odor problem.
Feb 16, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire pure source plus refridgater the ice and water in the door stoped working.
There are a number of things that can cause both the ice and water in the door to stop working. There are two control boards that sit behind the buttons on the dispenser. Either one of them may have failed.
There are several different types of dispensor controls on this refrigerator. You need to download the Factory Repair Manual for your fridge. It will tell you how to remove the dispensor cover and diagnos each board so you know exactly which one to replace. The Repair Manual will be the best source for you at this point.
Thanks
Jan 08, 2009 | Refrigerators
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
