Question about Motorola MU21CV (1 Channel) 2-Way Radio
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
  • 20 Answers
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Posted on Aug 11, 2010
Does a motorola gm300 model number m43gmc29c2aa have ctcss or PL TONES capability's?
Yes, it seems to me that the GM300 radios did have tones as programming options. They were programmed by the dealer using radio service software (RSS) when the frequencies and other channel information were entered. Of course, Motorola discontinued the GM300 a long time ago, and they were wide-band radios, so you could not legally transmit with them anymore. However, you could find someone on eBay to program them receive-only with or without CTCSS (PL) tones and then you could simply listen to them.
Jun 24, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
How to change frequency on gm300
To my knowledge the GM 300 can be programmed only with a DOS based programing software. Start with the DOS, not from the windows
Mar 12, 2009 | Motorola GP300 Compatible 2 Way Radio...
Motorola Radius CM 300
The CM300 is programmable using Motorola propietary software, cable and RIB (radio interface box). The software is primarily available to Motorola dealers. The easiest way to have the radio programmed is to take or send your mobile radio to a dealer. Typically programming is around $25 for this unit.
If you provide the model number, it would be possible to give you more information about your radio. It can be VHF or UHF, 25, 40 or 45 watt. You could also google the model number. The model number begins with AAM50...
Jan 17, 2009 | Radio Communications
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
Motorola GM300 Question
Check your antenna connections and coax for loose connections or damage. Also check your hand mic. See if the problem disappears if you turn on the radio without the mic attached. The two most common problems with a mobile radio are antenna and mic problems.
If you feel these are in order, it would be wise to have a tech look at the radio.
Aug 23, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Problems setting up Motorolla GM300
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Jun 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Motorola MU21CV (1 Channel) 2-Way Radio Logo
523 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
