Question about Dell Inspiron 530s Desktop Computer
Black screen with white arrow - Dell Inspiron 530s Desktop Computer
  • 570 Answers
Step 1: Opening a command promptThis error prevents Windows XP from opening. This problem has to be addressed from a command prompt environment. Use the following steps to open a command prompt environment:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears.The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
    NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CD's, press the R key to open the Recovery Console.
    NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
    1. Turn on the PC, and press the F10 key repeatedly at the first screen.
    2. At the Recovery screen, click Advanced Options .
    3. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
  4. When the log in prompt appears, press the number next to the windows version (min int or Windows) and type the log on password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: disk part
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
    • If a disk part prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
    NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered. For more information, refer to Performing a Full System Recovery in XP .
Step 2: Replacing the file from a backup folderUse the following steps to find and replace the L sass file from the command prompt environment:
  1. Type the following at the command prompt: CD X:\i386 (where X is the main drive letter)
  2. Press the Enter key. If the error The system cannot find the path specified appears, enter the following paths, in order, until the error does not occur:
    • cd X:\Windows\i386 (where X is the main drive letter)
    • cd c:\i386
    • cd c:\Windows\i386
  3. Press the Enter key, and type the following at the command prompt: expand lsass.ex_ X:\windows\system32 (where X is the drive letter)
  4. Press the Enter key, and type the following at the command prompt: cd X:\windows\system32 (where X is the drive letter)
  5. Press the Enter key, and type the following at the command prompt: attrib lsass.exe -r
  6. Press the Enter key, and type the following at the command prompt: rename lsass.exe lsass.bak
  7. Press the Enter key, and type the following at the command prompt: rename lsass.ex_ lsass.exe
  8. Press the Enter key, and type the following at the command prompt: exit
  9. Press Enter and the PC restarts without the error. If the error persists, go to the next step.
Step 3: Recovering the PC If the error still continues, recover the PC .
Please rate me if this solution works for you
Thanks......Have a great time.
Posted on Jul 12, 2010
M1 m2 m4 screen messaege
Utility button then stop 00 stop 01. Then use arrows to clear data screen then clear counters. Has the drum and developer been replace do that before clearing the counters
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 12, 2014 | Minolta bizhub 180 Black and White Copier
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
I have a dell inspiron 15 when I turn it on the dell symbol and insprion page comes up then goes to a black screen. When I press F8 I get black screen with white bars at the top and bottom and a white bar...
You are having a display problem with the LCD, so kindly have it checked from dell and get the LCD display replaced from them if your laptop is under warranty
Nov 18, 2009 | Dell Inspiron 8500 Notebook
Black/white
on the Finepix S700...on the back where the the LCD screen is you have the menu button with the four arrows around it. above the arrows you have the review button on the left and a silver button with an "f" on it. Hold the "f" button down for a few seconds and change it back to color. you have a few options so you may want to read what they are.
Sep 09, 2009 | Fuji FinePix S700 Digital Camera
Lost my instructions
Here's how to shoot in black and white using your Sony Cyber-Shot DSC-P73 Digital Camera.
1.Press MENU. The menu appears.
2.Select [PFX] (P.Effect) with </> (left and right arrow button), then select he desired mode (in your case black and white) with the up and down arrow buttons.
3.Shoot the image.
Hope this helped you!
Sincerely, CBR2009
Jul 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
Jul 21, 2009 | Nikon D50 Digital Camera
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Setting up scope
If background is black arrow must be white.No problem.Go to sky whatching.
May 10, 2008 | Bushnell 3" Reflector Telescope w/Talking...
Dell Inspiron 530s Desktop Computer   Logo
400 people viewed this question
Alun Cox
