Question about Beckett Water Gardening Beckett Statuary Pond Pump, 250 Gph
Beckett Pond Manuals
65 Gallon Stone Look Pond & Waterfall, PKF65....need manual to put together.
  • 9 Answers
SOURCE: Filter
You can build your own little filter by placing is in a container, like yorgart, with lid, but before you do punch holes into it no more than 1/8 inch all around. the more holes the better. this way your pump does not **** something into the chamber that will stop the propeller. I have done this and it works like a charm. Also you can use pond pots, the ones that have many slits in them.
Magnetic Drive Pond pumps can be left in the pond even if it froze. These pumps are great for weather. Once water unfreezes, pump will start again.
Posted on Jan 22, 2009
pondking
  • 21 Answers
SOURCE: beckett large pond pump
if by large you mean one that likes the photo you have picture it is a lost cause as it it epoxy encased and unrepairable. If thats the case buy a pondmaster or atlantic pump. proven performers that are repairable and very good warranties
Posted on Mar 23, 2009
clyde2j2
  • 137 Answers
SOURCE: How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Posted on Mar 28, 2009
  • 634 Answers
SOURCE: how do i keep my pond waterfall pump from floating
a simple cure is to put under a milk crate and cover with a rock, run hose through hole then easy to access and clean to boot
Posted on Jul 17, 2009
  • 151 Answers
SOURCE: my beckett 300gph pump trips breaker and works
capacitor,windings failing,
Posted on Dec 24, 2009
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Beckett waterfall / fountain pump W1800 pops breaker everytime you plug it in, consequently it won't run.
Sounds like there are too many things running on the same breaker. Try unplugging some of the other things on that breaker.
Oct 09, 2012 | RTO Beckett W1800 Waterfall Pump
How often can I add pond clarifier to the water
I found an answer on another pond company blog. They recommend once a week for pond clarifier and the same for the algaecide
Jul 26, 2012 | Beckett Water Gardening Beckett Corp 16 -...
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
How do i keep my pond waterfall pump from floating to the top
Jun 09, 2009 | Beckett Water Gardening Water Garden...
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Beckett Water Gardening Beckett Statuary Pond Pump, 250 Gph Logo
101 people viewed this question
Top Beckett Water Gardening Garden Experts
Morne Olivier
john h
Craig Butler
Craig Butler
Are you a Beckett Water Gardening Garden Expert? Answer questions, earn points and help others
