I have an LG 42LH30 TV on the factory stand. I want to put it into a wall unit that has a space exactly 1" shorter than the TV (width is fine). I can't use a wall-mounting bracket because the back of the piece of furniture is not strong enough. Can this stand be modified to make it shorter? There's a good 2.5" of space between the TV and the table-top. Any ideas?
  • pegoneil Jul 11, 2010
    I understand what Electronick's is saying & it would make sense EXCEPT the furniture is a room divider so the idea is to be able to see through it. The only truly strong supports are in the edges so the "beef up the back" solution would not look so great. It can be done but it's my final fall-back position. Does anyone know if LG makes a less fancy stand that I could buy instead of the swivel/tilt the TV came with?
    Yes, I think that the problem is I was trying to force the furniture I have and the mount I have to work. Too much trouble to re-work the furniture so I should buy a different mount. THANKS
  • 11,896 Answers
I would just drill new holes on the mount and then reposition everything so it fits.
TV with stand weight. 38.4 lbs
Posted on Jul 11, 2010
  • 2 more comments
    When you say "mount" do you mean the factory mount or the wall mount I bought separately?
  • Nate Stansfield
    Nate Stansfield Jul 11, 2010
    You can make your own holes on the wall mount. The table mount can be removed, cut and reinstalled as well to make it lower as well
  • Nate Stansfield
    Cheetah makes universal mounts. And you can cut off the access instead of having it stick out. They are also adjustable which I do think you might find handy.
    http://www.amazon.com/Cheetah-APTMM2B-Wa...
  • Nate Stansfield
    Not a problem! Thank YOU for using Fixya! Come back anytime!
  • 10,865 Answers
Hi. you can have the existing stand modified or have a new stand fabricated at most any sheet metal shop. j.
  • 505 Answers
You could double up the wood on the back of the piece of furniture, use some toggle bolts and then use the wall mount. Modding the stand would be more difficult than modding the furniture.. You could even just take a large piece of plywood or two 2x4s on the back of the furniture and sandwich the back of the furniture between the wall bracket and the newly added wood. Let me know how else I can help, but I think that's your best bet.. Make sure you have enough vertical space to put the tv up and over onto the wall bracket - need like 1 extra inch to get the tv onto the bracket. Let me know, best of luck!
  • thielectronick
    thielectronick Jul 11, 2010
    I would say you have a 1% chance that an alternate stand is available. I don't really know, you would likely have to build a custom stand or try to mod the one you have.. maybe cut off part of it? Best of luck
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
How do you take the stand off a lg 42lh30?
There are 4 screws to take the stand off your tv set the screws are near the stand to the back of the tv . when you unscrew them you should try taking the tv off by pushing it up .
Jul 19, 2014 | LG Televison & Video
I'm looking for an intall manual for an LG Gas Cook top Model # LCG3691ST, and a LG Fridge # LMX21984ST and a LG wall oven #LWS3081ST. Can you please help?
Hello Lola,
I understand that you need the installation documents for a few LG appliances you have. I would be glad to assit you in this endeavor.
LG Gas Cook Top LCG3691ST -
Product (36")
Width 36"
Height 3 34"
Depth 21 11/16"
Cutout (36")
Width 33 15/16"
Depth 19 11/16"
Minimum Spacing (30", 36") 1" Back, 11 13/16" Left, 11 13/16" Right
Net Weight 44lbs (30"), 50lbs (36")
LG Fridge LMX21984ST - http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LMX21984ST&matchedModelCode=1000004146&searchEngineModelCode=LMX21984ST&targetPage=support-product-profile&initialTab=documents
LG Wall Oven LWS3081ST - http://www.lg.com/us/appliances/pdf/LWS3081STss.pdf
The above gives you the need deminsions to install the units.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Kitchen Ranges
PS3 HOOKED TO 42LH30 THRU HDMI CABLE FOR A YEAR AND A HALF, WORKED PERFECT. ONE NIGHT USED BLUE RAY PLAYER AND THEN THE NEXT DAY NO PICTURE. REST UNIT SEEMS TO WORK FINE ON 480P. TRIED DIFFERENT CABLE SAME...
Hello my friend. Your PS3 might be near YLOD problem. GPU has been overheated and is almost broken and it can't render high graphics(resolution). You need to Clear the dust inside ps3 and let it "Power on" for 1 hour . If this not works. You have to give it to a near computer service shop to give it life again. Please Rate my help! Thanks!
May 11, 2011 | LG 42LH30 42 in. LCD TV
LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Feb 08, 2010 | LG 42LH30 42 in. LCD TV
42lh30 has bright spot in center
If the unit is under warranty, I would see if I could get LG to replace the LCD Panel. If is not under warranty I would try to live with it because of the cost to replace the Panel.
I hope this helps,
Skyassoc
Oct 31, 2009 | LG 42LH30 42 in. LCD TV
The screen goes complete blank with sound still on. It takes to shut TV off and power it on right away to get picture back-though the intervals getting shorter down the road . MY Screen goes black and I...
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Jun 01, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Tryiny to put my Akai LCT3201AD TV on the wall
For a set this size, there should be at least 4 mounting holes for a wall bracket. Please note that wall mounting is an option so the holes may be covered by plastic caps to hide the holes. These holes should be in a box shape around 1 foot wide or so.
Dan
Apr 10, 2009 | Akai LCT3201AD 32 in. LCD Television
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
