Question about Microwave Ovens
Heats, but think cooling fan may have stopped
My GE microwave, about a year old, doesn't sound like it used to when cooking. Afraid it may burn out something.
I think there may be a cooling fan that is not coming on, as it is a lot quieter than normal
  • Anonymous Jul 24, 2008
    Microwave heats, but cooling fan doesn't run. If the microwave runs long enough (several minutes), it will completely shut down -- probably a thermal cutoff.
  • pamelayvet Oct 11, 2008
    It started making a wierd noise and shutting down after cooking for about 5 minutes. It resets and turns back on after cooling down. It is two years old. Please help
  • Microwave Ovens Master
  • 9,086 Answers
If the cooling fan is not on, the magnetron can be destroyed.
It will have a full one-year warranty, then probably a 5-year warranty on the magnetron.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
I would contact them right away.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magnetron cooling fan
Are you sure it is the internal blower and not the VENT fan ?
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No light, internal fan...then no display
The light isn't a safety issue but I would think that the fan would be.
The fan is designed to remove excess heat from unit and keep it cool. Without the fan, you're now operating the unit under conditions that it wasn't designed for.
With the unit unplugged, try removing the cover and see if a fuse has blown. If so, replace it with the EXACT value of the original.
See if the unit powers up again. Try heating heating up something for 30 seconds to see if the Magnetron is still functioning.
If so, check to see if the bulb is good. Did the bulb and fan stop at the same time? If so, it might be something in common that controls both.
Don't operate it further until you have it looked at. You don't want to cause something else to fail.
- Jim
Jan 31, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
