Question about Microsoft Xbox 360 Console
No picture for xbox 360
My xbox 360 arcade has no picture when i turn it on. all the wiring is correct ive tried differnt tvs and differnt av cords . but it still dosent work please help.
    Sergeant:
    Champion:
  • 297 Answers
If you check the display cable and it is still connected then what can cause this error is the display chip overheating.
You can send it in and they will fix it for you or fix it yourself using a good repair guide
Posted on Jul 11, 2010
  • 176 Answers
Is this a brand new console? check the switch on the video cable
When i connect xbox 360 arcade[new] to my tv can't it to play
have you switched the switch to hdtv and NOT tv on the back of the big grey ariel plug going into your 360 ? then turn your tv to the aux or av channel as it wont be on a normal channel ??
Jan 26, 2010 | Microsoft Xbox 360 Console
When playing games my xbox 360, the screen will
try this. unplug everything (power cord, av cables, wireless adapter, controllers) and take off the hard drive. dont plug anything in for about 1-2 minutes. when the time is up, put the hard drive on first then plug everything else in.
Sep 27, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 plays game but recently has no sound? tried diff powercord and diff tvs still same problem. help
try a different av cord.yellow,red,white cord or what ever cord that goes to your tv.sometimes the cord gets broke where the audio is at and sometimes the system has a setting where it won't project sound
Jun 30, 2009 | Microsoft Xbox 360 Console
My xbox 360 keeps going from light to dark while watching dvds and when streaming from netflix. What can I do to fix it.
it could be your television or the av cords try another tv if that doesnt work then try a differnt set of cords if those fail then as a last resort try xbox help and email them.
Jun 22, 2009 | Microsoft Xbox 360 Pro System Console
New xbox 360 arcade no screen or sound
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
May 17, 2009 | Microsoft Xbox 360 Console
The 360 makes a sound on the TV but there is no picture
ther is a switch on the cords on the end of that plugs in your xbox it has TV--HDTV make sur that the switch is but on TV
Apr 17, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't show cuz of s-video
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Mar 06, 2009 | Microsoft Xbox 360 Arcade
Un recognisable picture
try a different set of av cables and or input on the tv and see what u get
Jun 21, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
