Question about Whirlpool Dryers
I get burn marks on my clothes. How can I solve
I get burn marks on my clothes. How can I solve this problem? Dryer is Whirlpool mod #LEC8611LW8
    President:
  • 1,554 Answers
Those are most probably not burn marks but rather stains, usually rust, due to a worn felt seal. The clothes get in contact with the metal surface of the cabinet when any of the front or rear drum felt seal gets worn. If that is the case, replacing the felt seals will address the issue.
Replace both the high-limit thermostat, thermal cut-off, cycling thermostat, and/or the thermistor if the marks are indeed burn marks. Check also to make sure that the vent duct is clear and the vent flap is fully open when the dryer is in operation.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from doing so. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 11, 2010
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Burning marks on clothes in dryer
how old is dryer. drive belt may be slipping. Unit may have a faulty control that allows element to superheat. You have a potential fire hazard. What type of clothes are getting the burn marks? Should they be dried in a dryer?
Jul 02, 2009 | Dryers
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Brown streaks left on clothes
Not having seen this before, but my best guess would be that the piece of clothes is caught in one position and rubbing on the gasket material around the rear of the drum. Is the mark permanent?
Apr 16, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Burn marks on clothes
problem is caused by drum seal usually the back one look closely at seal to see if there appears to be rust if so replacedrum seal ..clothes ten to rub against it while in motion causing brown streaks..would replace both front and rear just to be sure front doesn't give problems soon
Jul 26, 2008 | Whirlpool GEW9250 Electric Dryer
Open Questions:
Dryers Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
