Question about Whirlpool Dryers
Whirlpool Gold dryer has no power at all! Is there a fuse in the dryer it self? If so where would it be located?
  • Marvin
    Marvin Jul 11, 2010
    model number please
  • Whirlpool Master
  • 3,361 Answers
Unplug the dryer.
Remove the rear panel.
The fuse is on the blower duct to the left of the exhaust vent.
It is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
2 small wires are connected to it.
Check and clean your dryer ducts and connecting ducts and make sure there is good airflow or you will blow the new fuse.
Posted on Jul 11, 2010
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Dryer wont start
    ok your One Time Use Thermal Fuse is locater at
    copy n paste this;
    http://www.partselect.com/ModelFrames.aspx?ModelID=613741&ModelNum=GEQ9800PW1&mfgModelNum=&ManufactureID=3&Selected=8BBA2IJ6&Position=0&mfg=Whirlpool&Type=&Mark=0
    then click in the first box BULKHEAD PARTS
    go to item 59 .
    "Was this helpful?"
    if yes pleases rate my service thank you
    May 08, 2009 | Dryers
    No Power to Dryer
    Might be the ducting fuse located on the blowers housing has blown because of some kind of lint issue. LOCATION
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Feb 14, 2009 | Whirlpool LER5644J Electric Dryer
    Whirlpool electric dryer will not heat
    check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
    the emement limit is at the top of the blower housing and will have 2 red wires going to it
    the blower limit will have blue wires going to it
    withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
    Apr 12, 2008 | Whirlpool GEQ9800P Electric Dryer
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Dryers Logo
    50 people viewed this question
    Top Whirlpool Dryers Experts
    Sal De
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
