Question about Bosch Dishwashers
Seal round door leaks - Bosch Dishwashers
  • Bosch Expert
  • 414 Answers
If the water is noticed at the bottom of door it is probably the seal at the bottom (very unusual for the tank seal to leak, however it is just pushed in, so you could take it completely off, give it a clean up and put it back in) or one of the spray arms is restricted and instead of rotating the water is spraying continually at the corner of the door. Check all hole in the spray arms are clear and if you have a dishwasher freshener make sure it is not stopping the top spray arms rotation field. You could also check that the top arm is clear to move when your dinner plates are in the bottom basket (the top basket could have been moved inadvertently to the lower level).
Hope this gives you a starting point for checks.
ps bottom door seal is quite tricky to replace, so you may need to get an expert is the above tests indicate that that is the leak source.
Posted on Jul 11, 2010
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
Leaking drivers door
take off the inner door skin and check the polythene liner is fixed/sealed all round, as any gaps will allow water to pass into the car.....
Jul 13, 2010 | 2000 BMW 3 Series
Wire was sticking out and seal is loose how is it attached
Electric wire? Replace seal there is no adjustment for seal on door. Make sure door is not bent
Mar 09, 2010 | GE Energy Star WCVH6260F Front Load Washer
My Maytag side by side has frost that develops on freezer side
almost deffinately door seal.try hot cloth to warm seal and pull into shape ,close door ,if you look down seal it should stick to door frame all round.no air leaks...
Feb 11, 2010 | Refrigerators
A piece of fabric got caught in the seal and it it slightly torn and the seal is warped. A round wire with a spring fell out and the door will not close.
you will have to replace the boot glove as this is what i think you mean,the part were the door fits into,if there is a rip in this rubber boot then water will leak through teribly,the round wire you refer to is the wire that goes around the boot to hold this securely to the washer preventing it from leaking,hope this helps,rgrds,paul
Jul 07, 2009 | Kenmore HE2 Plus Front Load Washer
Leaks water when washing from the door
It's because of a hole in the door seal body. The water runs down inside the machine and comes under the front of the washing machine
For this first unplugged and then take the top off the washer and there is usually a nut and bolt to undo which is holding a clamp band round the door seal fixing it to the tub.
many cases where the water runs down from the bottom of the door but has in fact come from the soap dispenser but the leak was coming from the door.A thin line of water trickles from the soap dispenser and runs round the door frame to appear as a door seal leak. Make sure this isn't the case.
Thanks.
Kevin
Jul 04, 2009 | Whirlpool Washing Machines
LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Mar 16, 2009 | LG WM2688H Front Load Washer
Fitting of door seal on zanussi electrolux washing machine model aquacycle 1200 xc6 how do you get the the the door seal fitted finding it impossible almost
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Mar 12, 2009 | Zanussi FLA1201W Front Load Washer
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
Fisher and paykel 913T soft touch dishwasher leaking
They do not have bottom seal, problem possibly is door cabinet seal or loose dispenser leaking, just had that problem woth one of those the other day
Aug 31, 2007 | Dishwashers
Dishwashers Logo
101 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
