Question about Goldstar MV-1501 Microwave Oven
Goldstar MV1501BQ no heat
Oven seems to come on, but doesn't heat.
Tray also stopped working. Lights and fans work
Maybe fuse? location?
  • 2 more comments
  • LMGreen Apr 22, 2008
    I will try this and let you know. Thanks
  • Mepps56 Apr 30, 2008
    I Also have all functions but no heat. Microwave is only 2 1/2 years old? Any other suggestions?
    Thank you
  • SAllsop May 01, 2008
    I just purchased my microwave and 1st time cooking was luke warm, now it doesn't heat at all. the turntable is also sluggish acting. everything else seems to work. My microwave series is actually MV 1502 if that makes a difference.
  • LMGreen May 04, 2008
    actually, once I found the wiring diagram, I was able to determine that there was a loose wire connection at the upper door switch and it caused the switch to fail. I repalced the switch for about $10 and it is working just fine again.
  • 4,889 Answers
Hi LMGreen! Sorry for the late response a bit busy at work.. Coming back to the problem..
Solder joints on power control board are cracked and/or burned. Inspect solder connections on power control board for deterioration. This usually occurs where the harness connector is mounted to the circuit board. Reinforce and re-solder as necessary. Also check all other solder joints.
Posted on Apr 21, 2008
What would cause my Goldstar microwave to stop heating and the tray to stop revolving?
if timer and all other controls seem to work correctly id say a loss of high voltage section in microwave power generation part there can be several reasons for this a profesional serviceman can find more about why ?
Sep 09, 2014 | Microwave Ovens
I have an old Goldstar microwave (MV1140T) that just stopped heating. The fan still works but the food won't heat up. What can I do?
The problem is caused by a bad magnetron, "common problem" or the high voltage capacitor and diode, all three work together to heat the food. The repair cost for parts and labor will be high enough to consider buying a new microwave oven.
Feb 23, 2011 | Goldstar MV-1501 Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
I have a Goldstar microwave and it is not heating up the food. It is running the lights are on the tray is rotating but the food is not heating up at all.
heatman101//./.
Jun 24, 2010 | Goldstar MV-1526 Microwave Oven
No power but outlet is functioning properly
There is a ceramic fuse inside the oven. Remove the case and follow the cord from the back of the oven to the fuse. Replace with on of the same amp size.
Jun 19, 2010 | Goldstar MV-1501 Microwave Oven
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
May 25, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
131 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
SHARCNET-USA
SHARCNET-USA
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
